!!!!B Series AEM coil on plug Hondata ecu question HELP!!!
Old Feb 16, 2017 | 05:39 PM
Voltage johnson's Avatar
Icon4 !!!!B Series AEM coil on plug Hondata ecu question HELP!!!
Hey everyone I have a GSR swap on my 94 EG hatch with a Hondata ecu I've been looking at the AEM electronics Coil on Plug conversion kit but I was wondering if the conversion kit was compatible with the Hondata ecu please let me know if it is I want to use it over the hondata cpr set up
Old Feb 17, 2017 | 02:26 PM
FlewByU352's Avatar
Default Re: !!!!B Series AEM coil on plug Hondata ecu question HELP!!!
Short answer is no. The ECU's look for different sensors between the AEM and Hondata to control the ignition.
Old Feb 17, 2017 | 05:17 PM
DVDr's Avatar
long answer:
AEM EMS can do coil on plug with stock distributor. ( remove rotor, coil and use cap as a cover, or get fancy billet bwr cover ) . Then convert to direct fire ( if the AEM EMS has 4 coil outputs ) if not run wasted spark . If you wanted better input signal then you can run the AEM EPM ( that replaces completely the distributor and you MUST run a different ignition system eg coil on plug ) or you can run the hall effect sensor off the cam wheel ( eg T1 )
If you have hondata, then you can run the hondata conversion system ( CPR ) .
Old Feb 17, 2017 | 05:24 PM
FlewByU352's Avatar
Originally Posted by DVDr
long answer:
I'm failing to see where you are saying the AEM COP conversion kit can be used with Hondata. You even said AEM EMS, not Hondata. The OP wasn't looking to see if an AEM EMS can do COP with a stock distributor...
Old Feb 17, 2017 | 05:29 PM
DVDr's Avatar
I was trying to shed some light ( and for future searches ) on AEM being able to do it very simply and better than hondata in many cases ( as it gives the possibility of changing input signal ) .(but i dont want to enter the AEM vs hondata for the millionth time )
you can buy a V1 AEM EMS for much less than hondata S300 and CPR kit .
Old Feb 17, 2017 | 05:40 PM
FlewByU352's Avatar
Nice save on the edit because the CPR kit isn't waste spark. You're making Canadians look worse.
amtheiceman
Engine Management and Tuning
Nov 27, 2013 02:09 PM
viperjng
Oct 23, 2011 07:53 PM
JDMlyfestyle
Sep 27, 2009 10:23 PM
ivt-t
Jan 2, 2009 07:48 AM
Lmgrcivic
Feb 7, 2005 03:29 PM
