Civic ITR Mini Cooper 280mm TSX brake pad BBK complete NEW
Old Feb 16, 2017 | 01:39 PM
.Grimace's Avatar
footwork mastery
Default Civic ITR Mini Cooper 280mm TSX brake pad BBK complete NEW
SOLD SOLD SOLD
Forgot I had this in the garage from my old CRX. I ended up using this exact same setup but with NSX calipers instead. This all bolts right onto your civic for the best OEM big brake kit possible under 15" wheels. With the TSX pads you get no overhang and a perfect fit. You get 2 new 280mm base model mini cooper rotors (4x100)
2 remanufactured never taken out of their packing w/ brackets ITR calipers
a set of Hawk HPS pads for a 04-08 TSX for the perfect fitment
I loved this set up on my CRX and this thread should answer all questions. $350 shipped
http://www.team-integra.net/forum/19...gs-ls-gsr.html
Old Feb 16, 2017 | 02:10 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: Civic ITR Mini Cooper 280mm TSX brake pad BBK complete NEW
Do you still need to run a 3mm spacer with these rotors?
Old Feb 16, 2017 | 02:28 PM
da6er's Avatar
^^^ no sir. The mini rotors are already offset to the 3mm T bracket difference. I'm running them on my EM1 with Legend dual piston calipers.
Old Feb 16, 2017 | 03:08 PM
terqui's Avatar
No spacer needed. I used to run this setup on my EM1 before i got spoon calipers.
Note: you really need a 1" ITR master cylinder to maximize this setups effectiveness.
Old Feb 16, 2017 | 04:05 PM
2LEM1's Avatar
I like to party
Community Builder
So if it's the same size rotor (actually 2mm smaller), and the calipers are ITR, why are you not using ITR pads? I don't understand the overhang aspect... what overhangs?
Old Feb 16, 2017 | 04:06 PM
Caoboy's Avatar
-Intl Steve Krew
Active Streak: 120 Days
Loved
because you just explained why.
The pads are too big for the mini rotor.
TSX pads are a tiny bit smaller and fit better.
Old Feb 16, 2017 | 04:32 PM
da6er's Avatar
I'm using 04-08 TL pads on my setup.
Old Feb 16, 2017 | 05:28 PM
2LEM1's Avatar
I like to party
Community Builder
I looked into this once, but I was reading the TSX pads are actually too thick for the rotors, so the dude was saying you had to shave down the pads before installing them?
Old Feb 16, 2017 | 06:28 PM
.Grimace's Avatar
footwork mastery
I never test fit it with the TSX pads since I never bolted this on and went with the NSX calipers. Everything I read said you didn't have to worry about that and talked to countless people who used them with no issue.
Old Feb 16, 2017 | 09:20 PM
X32ragz's Avatar
What brand rotors are those?
Old Feb 17, 2017 | 10:22 AM
.Grimace's Avatar
footwork mastery
I'd have to double check when I get home. I used centric on the crx but can't remember if these were the same.
Old Feb 18, 2017 | 05:53 PM
.Grimace's Avatar
footwork mastery
Up
Old Feb 19, 2017 | 12:48 PM
dlx111's Avatar
Did you upgrade your knuckles to fit these? from what I remember reading, on an EG these wont fit the dx trim knuckle
Old Feb 19, 2017 | 12:50 PM
ShinsenTuner's Avatar
No Jodas
I have this setup on my hatch with ITR brake pads, everything bolted on as expected and the overhang is very minimal. Like ~1-2mm tops.
Old Feb 19, 2017 | 02:39 PM
.Grimace's Avatar
footwork mastery
i had an HF crx so I had to use da stuff for b series axles. I think dx does not work according to the article though.
.Grimace
May 5, 2017 07:56 AM
Noah Santana
Nov 30, 2016 04:57 PM
cheapskate
Nov 24, 2016 08:24 AM
!LL W!LL
Oct 16, 2005 12:22 PM
