99 Civic fuel in oil
Ive been working on a 99 civic ex with a d16, the car initially wouldnt start or do anything, had spark and fuel, compression wasnt the best, i figured out that it was dumping fuel in the cylinder because the ECT was toast. I lubed up the rings, cleaned the plugs and it started and ran for about 15 seconds, i smelled fuel in the oil, I feel like if i lubed up the cylinder walls and let it sit for awhile and let the fuel and crap evaporate from the cylinder and did an oil change it would run fine? I just need some thoughts, otherwise im guessing the rings are shot thanks!
85spraybomb
12
Nov 26, 2008 03:06 PM
