99 civic no spark after coil.
I read a forum on the no spark issue and performed the tests within the link. It stated that if you have spark at the coil and the rotor turns then replace the cap and rotor. I did that and I still have the same problem no spark out of the cap to the wires. Any suggestions for a cure?
did you use a high energy ignition spark tester? (dirt cheap on ebay)
if not you may have damaged the coil.
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
Erik Nielsen
Feb 15, 2017 05:07 PM
wellssc2002
11
Feb 2, 2016 02:46 PM
