Ac question(s)
Old Feb 14, 2017 | 11:12 AM
Cg_j30a's Avatar
Default Ac question(s)
So in December my Ac compressor took a dump on me. Since then I've had it replaced, and since it's been cold I never got the Ac serviced again to run cold air. Well my question is since replacing the compressor should I take my car to a shop to have it recharged or can I use one of those recharge cans that you can get from auto part stores. Thanks for the info in advance
Old Feb 14, 2017 | 09:36 PM
holmesnmanny's Avatar
Default Re: Ac question(s)
If the compressor exploded you will need to atleast replace the condenser and the drier, and should replace the expansion valve as well. Then have a shop check for leaks and pull a vacuum to remove all moisture then recharge to spec.
Old Feb 24, 2017 | 11:50 AM
Cg_j30a's Avatar
exploded? It went out while it was running. I smelt a burning sent inside the car if that's what you mean
carlove
Acura TSX
Jul 11, 2018 06:01 AM
threeoten
Honda Civic (2001 - 2005)
Aug 10, 2016 08:31 PM
vietnogi
May 24, 2005 08:01 AM
erikiksaz1
Sep 24, 2004 07:50 PM
