Hello.
I would like to ask if anyone knows if a 4WD 98 crv automatic transmission has a test port? If so could you post a pic of the location?
I called a Honda dealer and they said yes but didn't tell me where it is located, they only said "sure look on the transmission".
Reason being is that i want to install a glowshift trans temp gauge to monitor the trans temp when i pull a 800lb teardrop camper. 1/8 NPT threads on the sender.
If it doesn't then I guess i will install a T adapter to the hot transmission line going to the trans cooler.
I have never done this so any help would be greatly appreciated.
Thank you!
Pic:
