No vtec!speedometer not working fully.
Old Feb 12, 2017 | 03:55 AM
xlusiveracer's Avatar
Default No vtec!speedometer not working fully.
ok my problem is I would be driving and sometimes my speed needle would not catch the speed I'm going at and when it does the needle is not steady it's shaky..I have no cel for it And my vtec is not working..any help on how to fix either please
Old Feb 12, 2017 | 05:11 AM
civic402lx's Avatar
Default Re: No vtec!speedometer not working fully.
So what have you done so far to try and diagnose?
Old Feb 12, 2017 | 08:14 AM
Checked oil to see if it was oil it's still good.would it be. Bad vss that's causing the speedo not working right?i looked around and said some say it would be the vss if it threw a code only so I don't know
Old Feb 12, 2017 | 08:25 AM
civic402lx's Avatar
Check voltage on your VTEC solenoid. Make sure u are getting power. Undo the cluster and check for loose connection. Check connection at vss. Look for corrosion and whether its fray or firmly seated.
Old Feb 12, 2017 | 12:30 PM
09chaplak's Avatar
Loves Tossing Salad
So it won't rev past a certain RPM? What year and model are we talking about here. Check for loose grounds, thermos and such.
Old Feb 12, 2017 | 12:36 PM
r_Senik's Avatar
i know if its an obd2 car, if the speedo is bad, then vtec will not engage.
Old Feb 12, 2017 | 12:46 PM
mk378's Avatar
If the CEL is on for any reason, VTEC will not engage. And as 09chaplak said, there will be a rev limiter of around 4500 rpm. If you can take it up to the normal redline and it does not throw VTEC code, the VTEC is probably working.
I think the speed sensor code and CEL are not set unless the ECU sees a prolonged reading of zero while it concludes the car must actually be moving (zero TPS but rpm above idle, indicating the car is coasting in gear)
Old Feb 12, 2017 | 02:06 PM
no it will rev but my speedometer is not catching my speed.and once it matches the mph the needle is not steady
Old Feb 12, 2017 | 02:09 PM
can reach redline no vtec codes
Old Feb 12, 2017 | 02:10 PM
I believe obd1 it's 92 hatch
Old Feb 12, 2017 | 03:27 PM
HoangR's Avatar
Did this randomly start happening? Did you just buy the car? Did you do any recent mods done around the vtec solenoid/ top of tranny or gauge cluster? I'm assuming you're working with a D16Z6? More info will help us so we can help you.
Old Feb 12, 2017 | 03:43 PM
Originally Posted by HoangR
Did this randomly start happening? Did you just buy the car? Did you do any recent mods done around the vtec solenoid/ top of tranny or gauge cluster? I'm assuming you're working with a D16Z6? For info will help us so we can help you.
no i bought the car like this.did nothing to it recently.its a built b20 vtec.it does throw a code 43 when I don't fully warm it up.
Old Feb 13, 2017 | 10:51 AM
Badcopyinc's Avatar
i have a 94 ex coupe that does the same thing.
i work at a electronics repair shop that specializes is cluster repair.
and point blank two other techs told me flat out the clusters usually dont go bad.
i had abs codes that luckily told me the speed sensor from passenger side rear was bad. causing my slugish speedo and jerky symptoms.
Old Feb 13, 2017 | 12:54 PM
how do I fix the problem??i have my srs light stuck on if that helps anything
Old Feb 13, 2017 | 03:45 PM
mk378's Avatar
Is the odometer working properly? Drive a few miles on a road that has mile markers and check. If the odometer rolls steady and approximately correct, but the speedometer needle jumps around it is probably the speedometer head.
For SRS light you would pull the SRS code and go from there.
Old Feb 13, 2017 | 06:35 PM
Badcopyinc's Avatar
What I'm saying to check is your speed sensors first before doing any damage to the speedometer. The motors don't usually go and the solder usually doesn't have cold solder connections. Hence me saying that out of every car cluster we fix I've never personally pulled or worked on that year cluster. Chance of it being the cluster are very low if it wasn't altered.
You can check all your speed sensors and see if there's any damage. Also you can meter the speed sense wire behind the speedo it should read 65hz while doing 65 I can upload a photo of the pin out for the cluster while at work tomorrow. That will also tell you for free if it's your sensors or speedo.
Old Feb 14, 2017 | 04:30 AM
Badcopyinc's Avatar
looks like yellow with blue stripe going into cluster is your speed sense wire. tap into that run one to a multi meter and go for a drive. see what your signal is looking like while the speedo is jumping around.
Old Feb 14, 2017 | 09:07 PM
odometer works gas gauge and rpm work.sometimes the temp gauge goes jumps around sometimes too but never to hot it's in the middle and cold.
Old Feb 15, 2017 | 05:01 AM
civic402lx's Avatar
Did u even pull the cluster out to see if the connection is secured?
did u check connection at the vss?
Last time I had forgotten to torque the left front wheel, tight but not torqued to spec, during a test dry the speedo went crazy. Erratic, jumpy. Torque wheel down and problem fixed.
Old Apr 3, 2017 | 12:28 PM
Update I did check back connections to speedo everything looks good.also checked wires to vss.
Old Apr 3, 2017 | 06:36 PM
EsotericImage's Avatar
Retired Moderator
Check plug that plugs into VSS and also pins on VSS
Usually these get corroded and does exactl what your describing.
If they are corroded, use a small wire brush, clean the corrosion, be careful not to damage the plug or pins.
After they are clean, use some die electric grease on pins and plug
Old Apr 12, 2017 | 07:20 PM
Ok didn't get to fix my speedo but vtec does work.little did I know I had to take to 6k to hear.aftermarket cams was installed on car
ChargedLSVtec
20
Dec 10, 2008 01:31 PM
sleepingeg6
Nov 13, 2005 10:40 PM
631 Teggy
16
Mar 10, 2004 10:28 AM
Import RP
Sep 25, 2003 06:58 PM
90_Civic_Hatch
Sep 20, 2002 07:08 PM
