Help on build!
Old Feb 9, 2017 | 09:51 PM
92EgDelsol's Avatar
Icon3 Help on build!
I have a GSR block that im building to all motor.
I have completely stock bottom end , exept for Arias High comp pistons and Rods . HEAD is GSR ported and polished with new comp tech valves /dual valve springs. Cams are stock and so is the intake manifold. What changes would i need to get over 200whp N/A or is it possible with my current set up? Everything is new , new bearings aswell.
Old Feb 13, 2017 | 02:07 PM
trm4life's Avatar
Default Re: Help on build!
Light weight fly wheel, and poly engine mounts, or mount inserts will allow you to put more power to the wheels. Also consider a light weight crank pulley. Don't go cheap. I highly recommend exedy clutch, don't buy a bargain clutch. Other than that, you may consider throttle body, intake, injectors and fpr. However, without a tuned ecu, you won't gain anything at all. I personally have all stock internals on my integra, with forced air intake and tuned ecu. I gained 3 seconds on my 0-100!
BubsBoostedEG
Nov 28, 2013 08:31 AM
pitbulldrummer
12
Dec 20, 2010 09:27 PM
Tbone
294
Oct 1, 2010 09:46 AM
Antilag
Mar 1, 2006 07:17 PM
2ndgenteg-md
Sep 14, 2004 08:15 PM
