B16A vs. B18C crankshaft pulley
Old Feb 8, 2017 | 09:16 AM
Sprockets's Avatar
Default B16A vs. B18C crankshaft pulley
I searched through dozens of threads last night, but couldn't find an answer. The only info I could come up with is about the B18C5 ITR pulley vs. a regular B18. My car is a 99 Civic Si, but a shop installed a B18C1 shortblock 10 years ago, and I have no idea if they kept the pulleys that may have been on the block, or used the existing stock pulleys from my B16A. I just want everything to work as it should, and I'm not at all interested in an underdrive pulley. The reason I ask is because the GSR pulley is about $60 more than the EM1. Does anyone know what the differences are?
Old Feb 8, 2017 | 09:42 AM
ShinsenTuner's Avatar
No Jodas
Default Re: B16A vs. B18C crankshaft pulley
https://honda-tech.com/forums/acura-...ulley-2485359/
The second post says that the B16 crank pulley is smaller than the GSR's - which is true. On my engine, I have a B16 crank pulley and when I tried using an Integra alternator belt, it was too long and couldn't tension properly.
Old Feb 8, 2017 | 01:23 PM
Sprockets's Avatar
I'll order the GSR pulley, thank you!
TurboEM1
Aug 10, 2006 03:00 PM
incubus
Mid-Atlantic (Sales)
Nov 7, 2005 05:34 PM
work-in-progrex
Jul 29, 2005 01:37 PM
E-DA9
Jul 22, 2002 09:50 PM
EF8SIR
Jan 4, 2002 09:27 PM
