93 manual trans into 99 auto car- ecu question
Old Feb 6, 2017 | 11:18 AM
corpsebesideme's Avatar
Default 93 manual trans into 99 auto car- ecu question
I found a 93 ex manual trans i want to swap into my auto 99 civic ex... If the computer from the 93 trans is obd1 and my car is now obd2.. how does this work and what all needs to be changed?
I Have the new idle control valve and other **** (ive done a ton of research) but i need to know if the obd1 ecu can run everything else properly on my obd2 car?
Also during emissions- if i put the obd2 ecu back in to pass since my car is originally obd2 how is that gonna work with a 93 obd1 trans?? Im lost.
Old Feb 6, 2017 | 05:55 PM
r_Senik's Avatar
Default Re: 93 manual trans into 99 auto car- ecu question
why not find a 99 civic ex manual ecu?
manual transmission doesn't have anything to do with the ecu.
Old Feb 6, 2017 | 08:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
As long as the upper transmission bracket fits, you should be just fine. The auto ECU will not work properly with any manual transmission, however, if you need an OBD-2 ECU to pass annual inspections, simply purchase a manual ECU for the model year car you have.
Old Feb 7, 2017 | 12:35 PM
Im still lost- the trans im getting is froma 93 ex - my car is a 99ex- Can i run ANY manual 92-00 ecu and it will work? is that what you're saying? Sorry- still not clear.
Old Feb 7, 2017 | 12:45 PM
r_Senik's Avatar
Just buy a 99-00 civic ex manual ecu. its easier that way.
but if you insist on using another ecu from a different year, you have to use a ecu jumper harness.
Old Feb 7, 2017 | 12:56 PM
Ok , thats what i needed to know- so use a 99 ex ecu- so eventually im turboing the car; so then you would get the harness to run obd1 correct? Does the distrubtor and all that **** need changed once you run a harness for obd1? or just the harness and obd1 ecu needed? This is the only thing i cant directly find.
Old Feb 7, 2017 | 12:58 PM
r_Senik's Avatar
harness and ecu is just needed when switching to different obd ecu.
Old Feb 7, 2017 | 01:04 PM
Ohhh so only if an obd1 engine was put into an obd 2 car you would have to do all the other ****? thanks so much dude!!
Old Feb 8, 2017 | 02:11 PM
dx95civic's Avatar
You need a OBD1 alterator dizzy and injectors also
Old Feb 8, 2017 | 04:33 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
No, you want the ecu for your motor. You want the 99 EX Manual transmission ECU.
Old Feb 9, 2017 | 12:21 PM
Ok lastly can i use the 99 auto axles with the 93 manual trans?
Old Feb 9, 2017 | 01:34 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I don't believe there was any change to splines or the axles themselves between the auto and manual.
I am pretty sure the answer is yes.
Old Feb 9, 2017 | 10:04 PM
eghatch9295's Avatar
Stancetard Hate Monger
yes to the axles. 92-00 civic d series linkage, 96-00 d series m/t trans BRACKET, can re use trans mount. you'll need to convert to a 2 wire iacv, no matter if you use an obd1 ecu or the correct 99-00 ecu. an obd1 jumper/ecu do not care which distributor you use, etc. any other questions, don't pm me... use google. this **** has been covered to death.
highrev98civic
10
May 13, 2008 02:51 PM
99ekb18b
May 29, 2007 06:41 AM
bonez817
Jan 22, 2007 10:44 PM
murmur9
Aug 27, 2004 09:10 AM
