I've owned this car for ten years as a commuter car. Stopped running, think it may be the timing belt. Will not run. Will need to be towed. (Because Craigslist people can't understand this no matter how many times I emphasize it.)
Before it stopped:
230k ish miles.
5 speed.
No tranny problems, clutch is good.
Power steering, power windows,power locks, power sunroof all work, no leaks.
Heat and AC work.
Brakes are fine.
Clean interior.
Clean underbody.
Tires are good.
Things which may or may not matter depending on what your plans would be but need to be included for honesty's sake:
Exhaust doesn't go all the way back, cut off around the converter area.
Gas tank would leak if filled all the way but wouldn't leak if I filled it 2/3 of the way.
The hood release and lever are still there but not working. The hood is held down by two bolts, it's in the picture if you look.
Reason: Pictures
