96 Del Sol Clutch Fluid Drain/ Leak
Old Feb 6, 2017 | 12:28 AM
xboxhaxorz's Avatar
Default 96 Del Sol Clutch Fluid Drain/ Leak
I was driving my car after it was parked and noticed the clutch and shifter was not working well, i managed to get it to a safe spot well actually the car stopped and i couldnt shift into any gear aside from reverse so i reversed into a parking lot and looked under the hood to find the clutch fluid was all gone
I got some dot 3 brake fluid and filled it and the car worked fine, but about 2 wks later same thing happened, fluid is all gone
The car has 200k i on it, i bought it used as a temporary vehicle, how would i go about fixing this?
Old Feb 6, 2017 | 04:45 AM
mk378's Avatar
Default Re: 96 Del Sol Clutch Fluid Drain/ Leak
Find the leak, replace leaky part, refill and bleed.
Common leak points are the cylinders, the master cylinder will leak to inside the car and it runs down behind the carpet where it is hard to notice.
Old Feb 6, 2017 | 04:10 PM
akenwph's Avatar
bro sounds like its time to change clutch master and clutch slave also do em both at the same time so you only need to bleed once!
Old Feb 6, 2017 | 04:17 PM
civic402lx's Avatar
Both are cheap from exedyusa.. I bought both for 28$ shipped straight from exedy website. For under $30, its great OEM parts.. Without OEM price.
y-56
Transmission & Drivetrain
Jan 14, 2011 07:04 AM
richardman
Feb 22, 2010 07:21 PM
97delSolVTEC
Jul 24, 2009 08:08 PM
vinai
Dec 28, 2005 07:44 PM
rufridn
Dec 15, 2004 12:29 PM
