Question about Radiator Swap
doesn't matter. the only thing u have to worry about are the radiator mounts. u have to drill out the spot weld on both the two lower radiator mounts and a/c condensor mounts. then u have to reweld the two radiator mounts to fit the integra radiator. then u have to find mounts that will work for the top stock mounts will not work unless u drill new holes in your frame. what i did was i got sheet metal (thickness depends on u) and cut and then bend the sheet metal to fit. gonna take some time bending the metal. also u need the integra radiator hoses. (both the top and bottom hoses. stock civic hose won't work. any further questions just holla. latez and good luck.
well i don't need to worry about the ac cause it disapeared lol where it went i dunno
so i can get the rad from a 92 and it would be the same? if so i'm goin to get one soon
thanks
thanks
metroya_perform
Jan 21, 2008 05:46 PM
B18CYAAA
Sep 8, 2006 09:22 PM
lsvtec101
Nov 19, 2003 08:13 AM
