Power Steering Hose Sensor Hookup?
Old Feb 3, 2017 | 07:17 AM
jryKC's Avatar
Default Power Steering Hose Sensor/Switch Hookup?
Hi-
I am converting my Civic CX over to power steering. I have a full PS swap that was pulled from my '96 EX. I'm having a tough time time figuring out what powers and controls the sensor thats in the PS hose. The sensor is technically called the "pressure switch assembly". I've checked the manual without any luck. Is it something that just needs 12V with the key on?
Thanks!
Old Feb 4, 2017 | 03:57 PM
jryKC's Avatar
Default Re: Power Steering Hose Sensor Hookup?
Anyone?
Old Feb 4, 2017 | 06:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
No, that switch only closes when the steering rack is at full lock one way or the other and the P/S pressures increases... this causes the P/S pump to put additional drag on the engine, so the switch tells the ECU to raise the idle speed of the engine a bit to keep it from stalling. One wire is ground, the other is the input wire to the ECU.
Old Feb 4, 2017 | 09:35 PM
jryKC's Avatar
You the man. Thank you!
PaRRoWMaN
26
Aug 16, 2019 10:40 AM
577HondaPrelude
Sep 19, 2012 06:34 PM
Bradsxx7
Apr 12, 2009 02:36 PM
I3iggy
Dec 1, 2006 10:17 AM
