Y8 head On a Z6 Block Timing Issue
Old Feb 3, 2017 | 05:34 AM
Darrell Woods's Avatar
Default Y8 head On a Z6 Block Timing Issue
Cam timing issue. With a y8 head and Can do I use the Y8 cam gear to get proper mechanical
Timing? I got a Crower cam na stage 3 for a D16z6 with the Crower adjustable can gear. If I put the Crower Z6 can in the Y8 head, will it work? If so What timing gear Should I use to run the Crower Z6 cam in said Y8 head on my z6 block?
Thank you for All help in advance
Old Feb 3, 2017 | 12:12 PM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Default Re: Y8 head On a Z6 Block Timing Issue
I've no experience but from what I've read, use the Y8 Cam gear and you'll need a timing belt for the Y8.
Old Feb 4, 2017 | 11:52 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I was under the impression the Z6 block and the Y7/Y8 blocks were the same deck height so as to handle the longer rods. In which case the timing shouldn't be off the 1/2 tooth like it is on the shorter D15 block.
Old Feb 6, 2017 | 08:06 AM
24TEN's Avatar
PHANTOM MENACE
Correct. In this case there is no need to worry about timing change from the head swap BUT he's using a Z6 specific camshaft. Here he should be using the a 88-95 specific camgear (so as to treat the whole assembly as a Z6) if not already using an adjustable camgear.
Old Feb 8, 2017 | 06:37 AM
Thanks 24ten... And everyone else for your help.
Old Feb 9, 2017 | 10:44 AM
09chaplak's Avatar
Loves Tossing Salad
I remember when I had my adjustable gear for a Y8, it gave two separate settings, one for the Y8 and one for the Z6. I assume that means something is different then, yes?
Old Feb 9, 2017 | 10:48 AM
From what my investigations add up to. Yes. 7.4° difference between z6 and y8 cam gears
Old Feb 9, 2017 | 10:51 AM
cityofcaterpillars's Avatar
Use the z6 cam gear if using a z6 cam. That's what I have. It's essentially a z6 head if your using the cam
Old Feb 9, 2017 | 11:18 AM
24TEN's Avatar
PHANTOM MENACE
It's actually 4.73° difference, roughly half a tooth.
Old Feb 9, 2017 | 03:21 PM
360/38/2 = 4.73684210526°
Old Feb 9, 2017 | 03:46 PM
Math is not my issue. Tech is. Once I get the numbers I Can Figure out the rest..
Never the less. I Thank Everyone for there input.
Old Feb 9, 2017 | 08:09 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
OBD1 and I think OBD0 is keyed a half a tooth off of OBD2 motors. That's why you can adjust the half a tooth variance from the deck height of some mini me's by swapping the cam gear.
dustinbs144
Jul 15, 2010 01:56 AM
ef-hatchcrap
Jul 17, 2009 01:33 PM
jvillagran2000
27
Dec 3, 2008 05:06 PM
The Internet Tough Guy
11
May 3, 2006 05:23 PM
