EG Climate Control
Alright so recently my climate control button to blow the amount of air has stopped working recently. It worked fine a few days ago and now, if I switch it to 1-2 out of the 4 it doesn't blow anything. It only starts blowing my a/c or heater while on 3 or 4. Could it be a wiring issue? And on an unrelated issue, the lights for the whole a/c system don't work unless I hit a bump then they'll turn on. Another wiring issue?
*95 Civic Sedan*
*95 Civic Sedan*
This is probably a burnt out resistor. The resistor is in the top of the ductwork behind the glove box. You should also pull the fan and check for a mouse nest in the duct. The resistor needs airflow to keep it cool.
The panel lights could be a bad bulb or bad solder connections in the panel. Either way you need to remove the panel from the car. Resolder the circuit board and install new bulbs.
CincyCichlids
Jul 21, 2010 11:42 PM
Petah
Apr 18, 2002 07:11 AM
