Bad Ground?
Old Jan 25, 2017 | 10:07 AM
PsXtreme's Avatar
Default Bad Ground?
So ever since I got this 1996 Honda accord v6 I have had the issue of whenever I turn my turn signal on the entire dash flashes with the turn signal like the ABS light and the check engine light, that sorta thing. . I thought it could possibly be the alternator, but upon doing some research for other possible causes I found that the issue could be the alternator fuse or a bad ground. I have a chiltons manual and I looked up the wiring diagram for my turn signal lights and I only see the 100A main fuse and a 50A fuse as the only fuses it shows me on the circuit. I must be reading the diagram wrong or something because I know there is another fuse specifically for the turn signal lights. What I am hoping to get is some help figuring out where this alternator fuse is at and/or possibly locating the bad ground. I thought the ground wire that was being referred to was the ground that bolts from the engine to the core support and while that was pretty dirty, cleaning it up and putting it back on did not fix the problem. So now im not sure what ground wire to check. I suck at electrical stuff on cars so any advice would be helpful. Thanks!
Old Jan 25, 2017 | 05:04 PM
tamboo's Avatar
10 Year Member
Default Re: Bad Ground?
pm'ed you a link to free honda service manual fantasyland.
also get a haynes manual just for more info.
try ebay/amazon/allbookstores/bookfinder.
i got chiltons too but only cuz it was cheap lol.
prelude-all-the-way
Mar 20, 2008 07:38 AM
Accord1987
Classic Hondas
Mar 11, 2008 04:49 PM
show_time
Nov 24, 2007 08:29 PM
Diet coke boii
19
Jun 10, 2007 12:54 PM
dubxl152
Jan 21, 2003 11:00 AM
