Motor Mounts
Old Jan 23, 2017 | 04:47 PM
wildcatgoal's Avatar
Default Motor Mounts
I have a 1992 Accord EX A/T. I would like to replace the motor mounts. I see on Rock Auto there are two options for the rear - one with a Solenoid Valve and one without. Is there some way I can tell which one I have? What do I need to look for?
Old Jan 23, 2017 | 10:41 PM
1996accordlx's Avatar
Default Re: Motor Mounts
Go to a Honda parts site, such as hondapartsunlimited dot com, and put in your car and trim level. It will tell you which one you need.
Old Jan 24, 2017 | 03:26 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The engine mount control system comes on Accords with automatic transmissions. It is used to control excessive vibration at low rpms (e.g. idle). At low rpms, the PCM sends a ground signal (-) to the engine mount control solenoid valve, which opens the valve.
redlobster
May 14, 2019 03:08 PM
peterkemp47
Jul 30, 2016 11:03 AM
jmanuel
Jun 21, 2014 10:04 AM
Tu_Sae
Oct 11, 2007 06:15 AM
mozzy
Aug 29, 2004 06:33 AM
