No spark after theft recovery- '97 GSR
Old Jan 22, 2017 | 02:55 PM
jryKC's Avatar
Default No spark after theft recovery- '97 GSR
Hi guys-
Back in November my '97 GSR sedan was stolen and then recovered the next day. Needless to say the ignition column was pretty messed up when I got it back. Since the ignition switch in the column was broken the motor didn't turn over, the windows didn't work, and the fuel pump relay never came on. I was able to swap an ignition switch over from my junk Civic to the stolen Integra. The ignition switch harness is joined to the main harness with two big brown clips. There is also a tiny sensor around where the key goes in. Any clue what this does? So, after replacing the harness and the 50A ignition fuse in the engine bay I was able to get the motor to turn over. Everything appears to be working...lights, fuel pump relay, windows, etc. Unfortunately, it appears that I am not getting spark and the motor is slow to turn over (I tried two batteries). I removed the spark plugs just to make it easier for the motor to turn over but it was still very slow. Also, the radio can't power on. The anti-theft light just continuously blinks on it. Any thoughts on where to start?
Also, a portion of the actual ignition column was drilled out. I'm guessing the thieves had to do this because the steering wheel was locked?
Thanks!
Old Jan 22, 2017 | 02:57 PM
testify's Avatar
On vacation
Default Re: No spark after theft recovery- '97 GSR
Sounds like your batteries aren't fully charged.
Old Jan 22, 2017 | 03:02 PM
jryKC's Avatar
The second battery I used was just pulled off of the charger but I guess it's possible that it's weak.
I couldn't find my inline ignition tester so I just removed a plug, hooked the plug back up to its wire, turned off the lights in my garage, and cranked the motor over. I couldn't see any spark happening. I'm not sure how reliable of a test that is however haha.
Old Feb 11, 2017 | 05:34 PM
jryKC's Avatar
The motor now cranks over after replacing the starter. Still no spark. I replaced the coil to no avail.
Old Feb 11, 2017 | 06:27 PM
tony_2018's Avatar
Fish Twig
hear fuel pump?
Old Feb 11, 2017 | 06:43 PM
jryKC's Avatar
Originally Posted by tony_2018
hear fuel pump?
The fuel pump primes. Everything related to the turning of the key seems normal...i.e. fuel pump whine, CEL coming on and then off, etc. I even tried a different ECU.
The radio no longer powers on however. It simply flashes the anti-theft light whether the key is on or off.
Also, I do believe my car came with a dealer installed alarm. I wonder if that may be messing with things?
Old Feb 11, 2017 | 07:44 PM
mayfly's Avatar
yes! when i bought my eg back in 06(lots of love) it had a aftermarket alarm that would randomly engage and wouldnt start. completely removed it and problem went away
Old Feb 11, 2017 | 07:45 PM
jryKC's Avatar
Thanks for the insight, Mayfly.
Old Feb 11, 2017 | 08:21 PM
mayfly's Avatar
no problen. sorry for your luck, fckin thieves
Old Feb 12, 2017 | 03:22 PM
jryKC's Avatar
Had the ICM tested. It passed.
I found the dealer installed Acura alarm under my seat. Disconnected it. No change in spark.
eg6r4eva
Aug 20, 2012 08:31 PM
ONE-CAM-EF
Sep 2, 2009 05:15 AM
SinsEvil666
Jan 11, 2009 10:44 PM
sxm5369
Jan 11, 2009 03:04 PM
