92 Accord does not crank.
Old Jan 22, 2017 | 01:46 PM
thasickness's Avatar
Icon7 92 Accord does not crank.
I have new battery, starter, distributor and alternater. The lights turn on but does not crank. Not sure what else to check for. Does anyone know what it could be.
Old Jan 22, 2017 | 04:57 PM
tamboo's Avatar
10 Year Member
Default Re: 92 Accord does not crank.
is the starter motor denso or brand x or what?
do you here the solenoid clicking when turning the key?
cleaned relevant grounds lately?
do not just eyeball them lol.
Old Jan 24, 2017 | 12:10 AM
holmesnmanny's Avatar
You need to give a better history of what was going on before you started replacing parts. Perhaps the small connector for the starter isn't plugged in.
Old Jan 24, 2017 | 06:59 AM
I'm not sure what brand but I'll try cleaning the grounds today. Thanks.
Old Jan 24, 2017 | 07:06 AM
Well before the car would crank and thats with the new part installed then the battery died (lights would dim when trying to start it) so I left the car sitting for a while then I bought new battery and now it won't even crank. I know it has gas for sure.
Old Jan 25, 2017 | 05:11 PM
tamboo's Avatar
10 Year Member
cleaned both ends of your battery ground lately much?:hmmm:
Old Jan 26, 2017 | 12:47 PM
Yes I checked and cleaned both ends. I even tried jump starting my car and still no crank. Could my starter be going out even if its fairly new. Its a remanufactured one from mexico.
Old Jan 26, 2017 | 04:39 PM
tamboo's Avatar
10 Year Member
doesnt sound very reassuring, pull it out and take it back for a test.
it's worth the extra dough to get denso or other made in japan parts.
Old Jan 28, 2017 | 09:15 PM
You should check all the fuses in the engine fuse box assembly and the driver side kickboard fuse assembly, especially the 80a fuse in the engine box fuse assembly.
Then you can test the starting system with this Honda Acura Essential Electrical Repair Website. Troubleshooting Main Relay, Coil, Igniter, etc.
If you're not getting power to the small wire that connects to the starter it's possible the ecu is bad or if the car has an aftermarket car alarm, especially a Viper or DEA brand alarm it's possible the starter disable function of the alarm is malfunctioning. You can try jumpering the starter or push starting it(if you have a manual trans).
Aquila
20
Sep 28, 2016 05:59 PM
dwkirch
Mar 12, 2016 03:00 PM
kimbothegiant
Apr 15, 2014 04:06 PM
PePe240sx
Jun 7, 2011 01:37 PM
ramswood2000
10
Sep 27, 2010 05:20 AM
