Adding wires to injectors need help.
I'm trying really hard to find pictures of what anyone's means when it says add a wire to each injector in the intrusions for mpfi conversion. do I wrap wire around one of the pins on the injector and slide the plug over it? lol I don't think so. four wires go to the resistor box I know that. OK so the others existing wires go someplace but now need to go to the ecu as the instructions say. can I cut the other wire and solder the new one going to the ecu on to it?
Each Injector has 2 wires coming off of it. For arguments sake lets say you are using OBD1 injectors. All of the injectors share a 12v wire (literally splice all 4 of them together) (a15 @ ecu) The remaining extra wire on each injector will need to go to the ecu @ a1 a3 a5 a7
4d00rEF
Mar 26, 2010 03:26 AM
Jonathan_ED3
Mar 18, 2008 09:04 PM
Blaze45
Sep 23, 2003 11:43 AM
