Assistance Needed: Custom Velocity Stack Install 1998 Civic
Old Jan 18, 2017 | 03:23 PM
vmolla1's Avatar
Default Assistance Needed: Custom Velocity Stack Install 1998 Civic
Has anybody ever done this velocity stack that can help me out...
Could u tell me dimensions and wat degree bends i will need...
Old Jan 19, 2017 | 05:43 AM
StreetLethaleg6's Avatar
Default Re: Assistance Needed: Custom Velocity Stack Install 1998 Civic
You need to be more specific in your question, not 100% sure what you're asking. there are so many variables to set this up, motor, what material you are going use for the intake tract and etc. Example: I have a k24 motor with a ktuned passenger side rad....so the intake twists and the filter is coming through the drivers side front grill. Mine is setup for street and track, custom fabbed into two pieces. The intake is 3.5"-4", my velocity stack itself is 4"-7"......the main piece is for the filter on the street and the second piece has my velocity stack welded on. You remove the filter then attach the second piece onto the intake and it slightly protrudes through the front grill. I need more info on your setup and budget to further help you.
Old Jan 19, 2017 | 06:05 PM
FlewByU352's Avatar
Some people say the cucumber tastes better pickled. I used a 14' velocity stack of sorts.
9civichatch3
Apr 19, 2011 06:40 AM
B16A CRX
Oct 28, 2008 04:26 PM
itrdriver1071
Nov 12, 2005 09:46 PM
biggjimmy7
Oct 20, 2005 06:43 AM
