instrument cluster 1991 acura integra
Old Jan 17, 2017 | 09:54 AM
Dale Gneiting's Avatar
Default instrument cluster 1991 acura integra
hi, guys i have a question on my 1991 acura integra ls engine swap to a f20b (obd2b). Sence the old speedodometer was a maual cable type, how can i create a vss sensor signal to the ecm. A cable vss sensor that will sill use the cable and also send signal. I have made some checks but only the manual one with power steering lines into it has been is all that has been found. any help would so helpful.
thank you
Old Jan 20, 2017 | 06:09 PM
solomon93's Avatar
Default Re: instrument cluster 1991 acura integra
You will need a different cluster to work with the newer electronic VSS
Old Jan 20, 2017 | 08:05 PM
That is what I was wondering, so a 94-97 cluster was purchased. I was checking also if a repining or a new sub harness might help also.
Old Jan 20, 2017 | 08:57 PM
solomon93's Avatar
Subharness wont do you any good, but i would be sure i had the wiring plugs for the cluster as well.
GabesEF909
Sep 24, 2012 09:16 AM
evokiller666
Jan 27, 2009 11:47 AM
lopezchris21
Sep 18, 2008 11:40 AM
HomeBuilt
Nov 15, 2004 09:35 PM
Babybluegsr92
Sep 1, 2001 11:21 PM
