FS: HOLSET HX40 Turbochargers - Genuine
Old Jan 13, 2017 | 08:40 AM
Bseriescivic5's Avatar
Default FS: HOLSET HX40 Turbochargers - Genuine
I have two (2) Holset HX40w turbochargers off of "ISX" series trucks. Both are in great mechanical condition with absolutely no shaft play what so ever. Here is the break down on each:
1. First one has a frozen waste gate and will need to be repaired/replaced, or if you are running an external waste gate setup, this doesn't matter as you will be closing the flapper anyway. Also, the turbine retaining plate is missing. Again, minor issue that is easily fixed. See pictures. SOLD
2. Second turbo is in perfect shape with no issues at all other than some frozen turbine bolts on the v-band discharge flange where the down pipe would connect to. These should come out with a little penetrating lube and/or heat. $350 Shipped
Text/PM Greg for more information - (302) 359-2518
Old Jan 26, 2017 | 12:54 PM
Default Re: FS: HOLSET HX40 Turbochargers - Genuine
Reduced Prices. Up
Old Jan 31, 2017 | 05:19 AM
up
taytay
Jul 25, 2012 12:55 PM
Innes
Feb 16, 2007 02:30 PM
d.str0y
Feb 15, 2005 05:45 PM
94sohcEx
Feb 26, 2004 06:58 AM
