Sometime last year,I believe, Hasport came out with lower torque mounts for the 94-01 Integras and 92-00 Civics.
It says on the website that the Civics need some modification before installation. I called them and they said there is a plate you have to remove on the mounting area because the torque mounts are completely flat.
My question is has anyone bought these and installed them?
How did you remove the plate?
How is the feel on em?
Reason why I wanna buy em is that my engine is still swaying back and forth, even with Hasport 62a mounts all around. I currently have Hardrace Torque mounts, relatively new too.
Yup all three upper mounts, the rear mount, the driver side post mount and transmission mount all Hasport 62a, the motor wobbles back and forth on when slowing down with high rev i.e. 5000rpm on second gear.
could be just my crappy driving lol
forgot to specify the car it's a 99 civic with a b16
How'd this work out for you? I ordered a set to replace some ebay semi-solid mounts that are much more solid than semi, the 1500 rpm vibration gives me a headache. I didn't see a plate to remove, 93 civic.
I put on 60a mounts, they're awesome. The only thing is mount base is flat and holds the bolt holes about ⅛" away from frame. I used some thick washers to make up the difference and 3 months later, no issues.
This means that you are using the mounts on a Civic chassis, which has small alignment/locating plates welded to the bottom of the frame rails. You can either modify the mounts by cutting the bottom of them to fit around the locating plates OR drill the spot welds out of the locating plates and remove them from the bottom of the frame rails.
I have them here but they look identical i guess that's right?
they only sent me two long bolts and 4 big washers. I need 4 socket cap screws m10 1.25 pitch 40mm. Anything else doesn't fit right. Hard to find locally. Now i have to wait for those special bolts. What a pain in the butt.
Identical
that doesn't make much sense because the center hole of the mount needs to line up with the holes of the engine or transmission. Are your center bolts not at an incorrect angle with your washer setup?
no, i compared them to the solid mounts i had on that were dished to fit over the plate. I'll get a picture tomorrow.
email sales@hasport.com and i can send you instructions and replacement hardware
thanks, I ordered these from JHPusa, I'm in eMail communication with them about it now but i already ordered the bolts from Amazon and installed the mounts. They're awesome, thanks
