Please Help. VAFC Question
Old Nov 9, 2002 | 07:03 AM
BRICKHEAD's Avatar
Default Please Help. VAFC Question
I recently installed a VAFC in my 01 ITR. My " Check Engine " light came on and I am curious as to what could be causing this to happen. I am 99 % positive that everything is hooked up right so I am stumped. My mechanic friend is coming over to scan the system to see what he finds. I thought I remember hearing that the VTM signal wire was not supposed to be used or something. I am wondering if that is true and I am wondering what everyones opinions are on this problem. My friend is coming over soon so I would love to be able to cross refference what I find out here versus what he finds. Any help would be greatly appreciated.
Old Nov 9, 2002 | 07:37 AM
BRICKHEAD's Avatar
Default Re: Please Help. VAFC Question (JDM-R)
Please anyone?
Old Nov 9, 2002 | 08:37 AM
benmasters's Avatar
Have you read your CEL Code yet? thats the best place to start.
Old Nov 9, 2002 | 06:30 PM
Teepo's Avatar
Default Re: Please Help. VAFC Question (benmasters)
You should've gotten an updated wiring diagram when you purchased your vafc....i did, and my car runs fine. check your tps and map connections
[Modified by ITR1150, 10:30 PM 11/9/2002]
Old Nov 9, 2002 | 06:46 PM
Hybrid 350GT's Avatar
Default Re: Please Help. VAFC Question (ITR1150)
Check to see that the sensors are set at 6 and 6. That is what fixed mine. If that is not the problem, contact apex. Just e-mail them through apex.com. They respond fairly quick. I could be that sensor # setting, maybe a bad ground, I know that can do it as well.
Old Nov 9, 2002 | 07:21 PM
Art Vandeleigh's Avatar
Default Re: Please Help. VAFC Question (DOSPOWND)
what is there email?? i could not find one on their site?? only numbers...thanks!!
Old Nov 10, 2002 | 10:09 AM
Default Re: Please Help. VAFC Question (Art Vandeleigh)
I'll have to check when I get back to work on Monday, but I was just on there and noticed it was not there. There used to be an address in the same place the phone #'s were. I'll post my results tomorrow morning.
Old Nov 10, 2002 | 10:18 AM
Dave-ROR's Avatar
first verify that you have the sensors at 6. then pull the code.
http://www.bseries.net/html/garage/engcode.php
the code will tell you which wire you connected incorrectly. edit: so post the code(s) here when you check it.
[Modified by Dave-ROR, 2:18 PM 11/10/2002]
Old Nov 10, 2002 | 12:47 PM
BRICKHEAD's Avatar
Default Re: Please Help. VAFC Question (Dave-ROR)
I figured out the light but I was wondering what everyone has there two vtec engadgements set to. I am talking about where it kicks in ( Stock ) and where everyone has it turned down to.
bengay
Jul 22, 2006 05:10 PM
turbochargeb18c
Jul 14, 2005 06:45 AM
88SELude
Aug 7, 2002 11:17 AM
JdoggsGSR
Apr 27, 2002 11:29 AM
RedlineITR
Sep 10, 2001 12:58 PM
