94 integra rear sway bar question
Old Jan 11, 2017 | 06:20 PM
Iloveyourhonda92's Avatar
Default 94 integra rear sway bar question
Hey guys I just ordered a rear type r 22mm Sway bar from hmotors... It came with the bushings and end links, but then I noticed it didn't come with the brackets.. stupid question but can I make the stock 14mm rear sway bar brackets work or will I need to purchase the 22mm brackets?
Old Jan 11, 2017 | 08:50 PM
MotorMouth93's Avatar
10 Year Member
Default Re: 94 integra rear sway bar question
You shouldn't just bolt it on, with a Type-R rear sway bar (or any upgraded rear sway bar for that matter) you will ruin the subframe without a subframe brace, and that isn't an easy or cheap part to repair. Read these links, they talk about mounting it properly.
https://honda-tech.com/forums/acura-...ar-gsr-259297/
http://www.team-integra.net/forum/11...-subframe.html
Old Jan 14, 2017 | 02:28 PM
White_EG1's Avatar
Old Jan 14, 2017 | 02:36 PM
testify's Avatar
On vacation
I've seen that repeated to death on here and elsewhere and it simply is not true if you aren't offroading your car or ignorantly using an extremely stiff RSB with extremely soft spring rates.
khronicboy420
Suspension & Brakes
15
Mar 25, 2011 09:56 AM
Mikes2000civicsi
Mar 27, 2008 09:02 PM
Dorikamu
Oct 25, 2002 01:01 PM
