Coolant hose location
Old Jan 8, 2017 | 03:38 PM
Hybridguitarist's Avatar
Default Coolant hose location
so I have a 94 integra Ls frame and I'm putting in a 95 jdm B18C into the car. Almost everything is hooked up except for some coolant lines that weren't present when I got the motor delivered. The nipples that I'm pointing at are on the thermostat and there are two of the same nipples on the back side of the motor that you might be able to see to the right. My question is do I just run a length of hose from small to small and bigger nipple to bigger on the back side of the motor? Those are the only empty spots for hoses. Any help on this will be greatly appreciated so I can start this motor up.
Old Jan 8, 2017 | 04:01 PM
civic402lx's Avatar
Default Re: Coolant hose location
http://www.team-integra.net/forum/5-ti-pit-area/104149-skunk2-ranting.html
Look there. It may help. Study the photo closely, the small port look like its going to the other small port on the upper radiator hose piece.. If that make sense.
Old Jan 8, 2017 | 05:24 PM
That's funny because I just found one of those photos on google. And this will still help even tho I do t have the skunk2 IM, I just have the stock gsr manny. I'll snag these photos and use them to help finish this build. Thanks a bunch!!
Old Jan 9, 2017 | 05:06 PM
civic402lx's Avatar
Coolant still routed the same for both. Good luck with your build.
JScott3d
13
Feb 14, 2010 06:29 AM
Blacksheep0272
Oct 17, 2009 09:03 PM
gassaversracing
Jun 21, 2005 12:17 AM
untitledsn41
Sep 12, 2004 08:09 PM
Infamous_Imports
May 9, 2004 12:15 PM
