noticed something wasnt hooked up after swap
ok, i just noticed i dont have two hoses hooked up to my motor. at the middle of the firewall there are 2 tubes coming out of it (look like small radiator hoses) and they arent going to anything. i remember when i pulled my old motor out i remember disconnecting them and anti freeze came out of them. anyway there is no spot on my motor (b18c) for these 2 hoses. is this bad...and could this be why my Heat doesnt work?
feel free to ask some questions if i didnt explain something right
edit: do i have to disconnect some hoses and make it work.?
Re: noticed something wasnt hooked up after swap (mwieczorek43)
i need some pics to see what you mean, i believe it is the heater hoses though because i took the same ones of of my friends teg and coolant leaked out. pics please
those are your heater hoses. the heater core heats up air with coolant that has been thru ur motor. they should hook up to your motor in exactly the same fashion as your old motor. you probably have the heater hose inlet/outlet looped together on your motor
Re: (dantastic)
k, well i take it the longer hose hooks up next to the fron radiator hose...but where does the shorter one hook up to...can someone who has the same swap as me maybe take a picture or maybe walk me through where they hook up to
