Assistance NEEDED: Turbocharger Oil drain route & level question
Old Jan 4, 2017 | 10:07 AM
Honda_Cribb_GS-R's Avatar
Default Assistance NEEDED: Turbocharger Oil drain route & level question
I have a b18b turbo and I usually run my oil level at the top dot on the dip stick. I was under the car and notice I few things that worried me. In the pics below us can see alittle burnt oil on the exhaust housing.
​​​​​Don't know if im running to high of a oil level, so I took the oil drain line off at the pan on level ground and about 3/4 a quart came out. This is how high my return bung sits.
After the oil stopped coming out the return bung I rechecked the oil level and it was at this.
Should I try running the oil level between the 2 dots? I really don't feel comfortable running the oil on the bottom dot due to some oil going in the catch can. Thanks for any help.
Old Jan 4, 2017 | 11:01 AM
TheShodan's Avatar
Moderator
Default Re: Oil level question
You're creating a small oil back-up condition, and the oil splay is bypassing the oil sealing ring in the CHRA of the turbocharger itself and is "coking" (in which you're seeing the oil sludge out of the turbine housing bolt, which is right at the rear portion of the turbine shaft and heat shieldthat is part of the CHRA), which may explain the loss in oil on the dipstick itself. (The oil level should be slightly higher towards the upper dot of the dipstick). If the turbine housing were removed, you'll see caked up sludge on the turbine heat shield and "coked" oil on the turbine shaft itself. The oil you're missing on your dipstick is being collected there... eek!
The reason why you have an oil back-up condition is because you're using a 90 degree fitting right off of the turbo into the oil pan at a straight angle, when the oil pan needs to be "gravity" fed. ("Gravity" feeding the oil pan is done by allowing a slight downward-angled "slope" to the oil pan return flange bung.)
This is from your exhaust manifold seating the turbocharger too low to the level of the OEM oil pan. You may have be resorted to:
1) replacing the 90* fitting with a 45* and allowing a small slope downward to the new location AND
2) relocating the oil drain fitting a few millimeters lower on the oil pan
As of now, you're fine, but you don't have a lot of time to perform this. The rear oil sealing ring will allow for a bit of oil to bypass into the turbine housing for only so long, then you'll have damaged both the oil sealing ring and the turbine shaft of the turbo.
Warning Note: PLEASE CEASE ALL DRIVING UNTIL YOU HAVE REPLACED THESE COMPONENTS.
Old Jan 4, 2017 | 03:57 PM
Default Re: Assistance NEEDED: Turbocharger Oil drain route & level question
Thanks shaldon I have a 45 degree 10 an fitting I can use, so I should also move the bung down a few millimeters? Also the oil level leave it at the second dot?
Old Jan 4, 2017 | 07:37 PM
2kdrift's Avatar
I would say put the 45* on there and see what it looks like before resorting to moving the fitting on the pan you can post pics once that is done for a second opinion, and fill your oil up properly to the top dot which is max oil. The second dot is the minimum oil you can use and if it goes any lower it can cause damage to your engine
Old Jan 5, 2017 | 05:11 AM
Ok I will add the 45 degree fitting today after work report back thanks again guys this build/turbo only has about 250 miles on it so hopefully the turbo is still ok
Old Jan 5, 2017 | 01:32 PM
boosted94gsr's Avatar
On my mini ram setup I had to run a 45 degree barb fitting to get the right angle, my 45* AN fitting would hang way too low. I also trimmed the lip off of the threaded plate that mounts to the bottom of the turbo and retapped it to get more elevation. Here is a pic of my setup. Hope that helps.
Old Jan 5, 2017 | 01:56 PM
2kdrift's Avatar
do I spy a Myhondahabbit lol. Just ordered my replacement had to pull my pan
Old Jan 5, 2017 | 03:35 PM
Yes sir you do lol. I got the stud kit with it as well. Hasn't leaked a drop since I've installed it
Old Jan 5, 2017 | 03:48 PM
2kdrift's Avatar
same story with me, got the stud kit as well... kinda pricey but well worth it IMO
Old Jan 6, 2017 | 03:52 AM
I tried a 10an 45 and it wouldn't work think I might have to go the 45 degree barb fitting like yours boosted94gsr.
Old Jan 6, 2017 | 06:20 AM
LightningTeg's Avatar
Community Builder
I did it like boosted94gsr as well
Old Jan 6, 2017 | 06:55 AM
Thanks for the reference picks! I'm going to try this before moving the bung hopefully this will help. Are yall using a 1/2" NPT to barb fitting?
Old Jan 6, 2017 | 08:58 AM
Community Builder
Yup
Old Jan 6, 2017 | 10:01 AM
I actually copied you lightning lol.
Old Jan 7, 2017 | 05:51 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
i think im going to have to do this as well. my old garrett t3/t4 i think is slightly smaller than the predator i bought from Shodan in which my return line setup may be slightly longer and i cant get the angle i want. not to mention this on moroso oil pans. they need to add a secondary bung on the other end of the box portion of the pan. tbh, i think the moroso oil pan is designed for a top mount turbo due to the location of the return bung. looks like i might be removing my pan to get this hole made on my oil pan.
Old Jan 9, 2017 | 02:45 AM
Community Builder
Yeah the moroso location is not ideal at all.
Old Jan 10, 2017 | 01:31 PM
where did you get that fitting for your oil pan? ive been looking for that fitting and im having trouble finding it
Old Jan 10, 2017 | 02:21 PM
Looks like a 1/2" npt female bung to a male 1/2" npt to 5/8" barb fitting.
http://m.ebay.com/itm/NPT-1-2-Aluminum-Weld-in-Bung-Fitting-Adapter-/262438076219?hash=item3d1a873f3b%3Ag%3ACtQAAOxyBotTY1T8&_trkparms=pageci%253A65fa098d-d78b-11e6-8e3b-74dbd18050d9%257Cparentrq%253A8aaef65a1590a2a216820fc7ffc11936%257Ciid%253A2
http://m.ebay.com/itm/5-8-Hose-Barb-to-1-2-Male-NPT-High-Quality-Brass-Ships-From-The-USA-/291862277119?hash=item43f458ebff%3Ag%3Acx8AAOSwdIFXyERE&_trkparms=pageci%253Ae21742d3-d78b-11e6-a572-74dbd180021f%257Cparentrq%253A8ab223be1590a2ab85666163ffc00d27%257Ciid%253A12
Old Jan 11, 2017 | 02:59 AM
Community Builder
Which one? The barbed fitting was from Lowes or hardware store. 1/2" NPT Barbed
Old Jan 11, 2017 | 07:54 AM
B and B's Avatar
Loved
Community Favorite
The actual weld-in bung....will probly have to be sourced online, unless your area is well supplied.
Need steel, btw, unless you have the baller aluminium pan.
I got one at a diesel shop, but it was bigger in every dimension than needed/wanted.
Of course I used it anyway being impatient, and ended up with kinda shitty result.
Yes, Moroso pan sucked for location.
Looks like those MHH gaskets are made of what the OEM valve cover gaskets we used to sell for L series Datsuns were.
Wonder why no other aftermarket makers have caught on? Cuz I want CHEAP!
Might have to cough it up tho, tired of the nasty leak.
Old Jan 11, 2017 | 08:03 AM
Community Builder
It was a jegs weld in steel bung. $3~ iirc. Be aware the moroso pans are galvanized inside and out, so grind off the surface coating and/or wear a respirator while welding it.
I also have the ARP oil pan stud kit.
Old Jan 11, 2017 | 08:04 AM
B and B's Avatar
Loved
Community Favorite
All that oil isn't in the pan when engine is on and pumping btw...as was pointed out to me (duh) when I made the same observation last year.
Old Jan 11, 2017 | 11:05 AM
2kdrift's Avatar
Yea they seem fairly simple, some type of fiber/paper like material. they do seem a bit overpriced however they dont leak. Im in the process of removing the old gasket which is a pain, had to remove my pan one of my oil squirters got destroyed, piston skirt must have made contact.
Old Jan 11, 2017 | 11:09 AM
**** my bad I thought the moroso pan was aluminum.
Old Jan 11, 2017 | 12:41 PM
thanks ill check it out and i also have the my honda habit stud kit so im covered there. ill probably wont use a barb fitting on my return line
