Cable Reel or Clockspring Replacment for '99 Civic EX
So my clockspring(cable reel) I think is busted. My horn didn't work and my SRS light was on. I was looking for my part but it seems my part #77900-S04-A91 is more than I want to spend. I can't find any uses parts on ebay or auto stores near me. A new one cost $70+. Mine also has cruise control which I never use. I just want to use my horn and make sure my airbags works.
I thought about going to the junkyard and pulling one. But I'm not sure what I'm looking for to make sure it is compatible. Any suggestions.
here is a diagram:
77900-S04-A91 | Genuine Honda Reel Assembly, Cable (Sumitomo) - HondaPartsUnlimited.com : Honda Parts Unlimited | Genuine OEM Honda Parts & Accessories
if you cant find in local boneyard try :
Car-Part.com--Used Auto Parts Market
Does cruise control definitely not work? Last time my SRS light came on, it was the SRS control unit under the dash that failed. I only found that after after replacing cable reel first.
If you've got a good pick-n-pull near you, you should find one for short money, or see if someone is parting a Civic near your on CL.
Be sure to follow the install procedure on these so that it's clocked correctly.
Honda97
Nov 14, 2004 09:29 AM
