2000 Accord 2.3 fuel problem
Old Jan 3, 2017 | 08:34 AM
Doug6465's Avatar
Default 2000 Accord 2.3 fuel problem
I have a 2000 Honda Accord 2.3 and will not run. I am having fuel issues. Let me get a few things out of the way. The engine has spark at the plugs. New wires. New plugs. The fuel pump is fine. The fuel regulator is new. The return line is not clogged. The only way I can get the car to stay running is if I take off the fuel line. When I put the line back on the car will not start. After a couple of attempts to start the car I remove the plugs and they are black and wet. I know this sounds crazy but it is a big mystery to me.
Old Feb 4, 2024 | 05:12 PM
Teebo60's Avatar
Default Re: 2000 Accord 2.3 fuel problem
i hada fuel problem with my 01 accord where it would start run fine the shut off an
wouldn't start back after it cool down it would start i tried every thing coils immobilizer so on it turn out there is a fuel pressure relay under the driver side dash i read where some one had the same problem it was broken solder joints on the fuel pump relay i didn't have much faith but pull it out redid those connectors and never had anymore problems it took 5 minutes and id been try to fix it for a month maybe it will help
Michaelman
Classic Hondas
Apr 14, 2018 01:14 PM
McDonald_M
Jul 4, 2015 06:03 AM
dagle
Jan 26, 2014 08:13 PM
00Civik
13
Aug 22, 2011 06:37 PM
