Suspension & Brakes Theory, alignment, spring rates....
Proportioning valve question with pictures.
Old Jan 1, 2017 | 01:10 PM
BongoBennie's Avatar
Default Proportioning valve question with pictures.
I am installing the proportioning valve from a non ABS 03 Civic LX (10.3" disc with drum rear) into 02 Insight with the same 10.3 brakes/calipers and the stock rear drums. I have done a lot of googleHT searching and want to confirm the brake line routing is correct. The two lower ports being the inputs from the master cylinder and if this is correct (rears opposite fronts) in theory it shouldn't matter if the two inputs are switched?
Please set me straight so I can get to work, Thank you!
Old Jun 19, 2018 | 09:13 AM
Rated R345's Avatar
Default Re: Proportioning valve question with pictures.
Sorry to bring back such an old post but I would like to know if this is correct as well.
Drew661
Feb 13, 2017 10:23 PM
sinyce
Aug 2, 2016 10:48 AM
dices543
Jun 3, 2010 11:50 AM
89efDUSTY
13
Mar 26, 2007 11:20 PM
litterbox
18
Apr 7, 2005 05:56 PM
