Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Clicking type noise coming from suspension
Old Dec 31, 2016 | 07:00 PM
HondaLuv3r4Life's Avatar
Icon5 Clicking type noise coming from suspension
Hey everyone. My 06 R18 has a what I would describe as a sort of popping/clicking type noise coming from the suspension. It seems to happen mostly when traveling at low speeds over slightly unlevel ground. It seems to be coming from both the front and back. Currently the car has 181k on it and I know nothing about suspension. Can anyone make some recommendations on what I could have my tech check for? It's really getting annoying. I know my shocks are totally shot. Planning to do them in the next week or so. Any help would be appreciated. Thanks!
Old Jan 2, 2017 | 01:02 PM
97emsedan's Avatar
Default Re: Clicking type noise coming from suspension
Check your sway bar bushings all 'round and make sure your spring seats aren't crumbling/ crumbled.
Old Jan 10, 2017 | 09:40 AM
Icon5 Re: Clicking type noise coming from suspension
Ok. What do the sway bar bushings do? Like I said I know nothing about suspension. If they are found to be bad, is it bad to drive around long term with bad sway bar bushings? And with the spring seats, how often should both these items be replaced? My technician already did my back shocks. I'm told the shocks have a part called a Strut Mount, my service writer told me that they need to be replaced every time you do shocks on a Honda. I don't believe they replaced the Strut Mounts just the shocks.
Old Jan 10, 2017 | 03:51 PM
97emsedan's Avatar
The strut mounts are part of the front suspension. They complete the assembly known as a McPherson Strut. The swaybar bushings isolate the swaybars from the body of your car and if they start to crumble ( age and wear will do this ), the swaybars will start to knock against the chassis. Swaybar end bushings do the same thing except they are at the ends of the bars and absorb shocks from the other suspension components during motion.
any of these bushings will wear over time and could be what's causing your knock.
Old Jun 4, 2017 | 02:46 PM
I'll try to get a video clip sometime soon. Just need to remember how to post them.
Old Jun 14, 2017 | 02:34 PM
racer131's Avatar
if its at slow speeds could be a shock top if not a lower control arm bushing
Old Jun 14, 2017 | 05:34 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Clicking is usually associated to CV joints. But could be as others mentioned, totally shot bushing to the point the center post/bolt is bouncing between a metal sleeve.
Old Jun 15, 2017 | 07:13 AM
Odixeus's Avatar
Well, maybe you could check the front springs and look for some foam/plastic? Good luck with that. I know it may be annoying.
vamshi
Suspension & Brakes
May 8, 2018 08:51 AM
HondaLuv3r4Life
Nov 1, 2016 09:44 AM
doubleoazn03
Suspension & Brakes
16
Apr 24, 2012 02:21 AM
cho76ers
Oct 30, 2005 09:19 AM
