Honda Civic 98 With Y8 High Idle, Vaccum Leak?
I have removed my y7 intake manifold and installed a Y8 intake manifold (98) on this car while keeping the same same y7 throttle body. But now I am having a high idle problem, could this possibly a vaccum leak?
Video:
Video:
Do a smoke test, see if u can locate the leak. Mine was idling weird when I did the y7 to y8 manifold swap. Turns out I had too much tension on the throttle body clamshell spring. Causing a very tiny air leak directly behind the coil spring. Couldn't find the leak til I did the smoke test.. Then it became clear. After that, it idle perfect. Still idle perfect.
Also, check your throttle body gasket. Make sure I use the correct one.
91 crx savage
28
Jul 27, 2010 11:10 AM
MildWater
21
Mar 7, 2007 12:27 AM
max23
Oct 18, 2005 06:14 AM
