vtec po420
Old Dec 31, 2016 | 06:46 AM
youstolemybeer's Avatar
5 Year Member
Default vtec po420
Hi, I just replaced the vtec gasket on the 2000 civic ex, It was cold as heck out so I used a heat gun on the solenoid/head for about 20 minutes to keep the Loctite gaket sealer warm so it would cure. Now I am getting a po420 cel.
Do you think the 2 are related or just a coincidence
thanks
Steve
Old Dec 31, 2016 | 07:21 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Default Re: vtec po420
Doubtful.
You need to list the make and model of the car.
P0420 is the Catalytic System Efficiency Below Threshold
The service manual lists the probably causes as:
- Three Way Catalytic Converter
- Secondary Heated O2 Sensor
This is from the 96-00 civic service manual
Old Dec 31, 2016 | 07:37 AM
5 Year Member
2000 civic ex all stock
I did have to take the fuel injectors out and the throttle body off to be able to get a drill to fit (bolt broke off in the head at the vtec solenoid).
97civic07gsxr
12
Feb 14, 2009 10:50 PM
stifferd
Jul 25, 2003 09:02 PM
2qwik2nv
Jul 21, 2003 07:46 AM
