00 Civic - Any way to read fuel level
The stock sensor in the tank is just a variable resistor to ground. High resistance (40-50 ohms) means the tank is empty, becomes almost zero ohms when full. It's not going to be much mathematically proportional to the number of gallons in the tank, it just goes from "F" to "E" as the tank empties.
Yes, of course you have to unplug the cluster or take the gauge out so that it is not in the circuit. As I said, there is one wire going back to the tank that provides a resistance to ground which directly drives the gauge on the dash. It isn't connected to the ECU or anything else.
Papalou
Feb 23, 2014 09:31 AM
lancerkid06
Jan 2, 2013 06:01 PM
VihnSta2
14
Apr 12, 2010 06:14 PM
JDM_Spec_SI-R
Sep 20, 2006 05:53 PM
