Poor MPG D15B7
Old Dec 27, 2016 | 06:18 AM
Marc87_RO's Avatar
Default Poor MPG D15B7 [solved]
Hello,
I`m driving a 94` EJ2 Coupe (DX) in Europe and MPG sucks.
I found no answers in other threads, like:
https://honda-tech.com/forums/honda-...leage-1035028/
What I know so far:
Driving like grampa.
Stock engine. 240k Km
No cel code. (cel is working)
Stock ECU P06.
Timing belt is new + set on 16 degrees BTDC.
New spark plugs.
New fuel filter.
New air filter.
New o2 sensor.
TPS sensor is working ok 0.5V - 4.5V at full open.
Valves are adjusted, cleaned, all good here.
Good tire preasure.
Fuel is good quality.
No leakings.
Engine olil level is ok.
Engine temperature is ok.
Custom final exhaust.
On deceleration my exhaust backfire quite a lot, Is this normal cuz I have a custom exhaust?
Car is running just fine, no issues, starts up ok, normal engine performance.
30 MPG outside the city is kind of crap for me, any suggestions?
Thank you!
Old Dec 27, 2016 | 08:02 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Poor MPG D15B7
It's winter, fuel economy always goes down during winter.
Also, is your car an automatic or a manual transmission?
Old Dec 27, 2016 | 08:13 AM
Marc87_RO's Avatar
Hi, thank you for the reply
My car is a manual 5 speed, stock gearbox.
combined MPG 28
hwy MPG 30-31
city MPG 25
Old Dec 27, 2016 | 08:21 AM
civic402lx's Avatar
injectors clean. Maybe it will help.
Old Dec 27, 2016 | 08:23 AM
mk378's Avatar
Did you jump the service connector to set the timing? If you try to set it in normal run mode (connector not jumped), you'll end up with it way late.
Old Dec 27, 2016 | 08:25 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I would suggest doing a compression test. If the motor is tired it won't be as fuel efficient. Also, it is very probable that you have high amounts of ethanol in your gas. This lowers MPG. Pure gasoline gets way higher gas mileage than gas/ethanol mix.
Please study the table below as it is 3 years of monitoring two D15B7 motors in my manual CDM CX (USDM DX) hatchback:
MPGOdometerLitersDistance TravelledDate
0.00299521.137.1300.02/17/2013
30.1830002539.270503.92/24/2013
29.87300489.436.570464.43/1/2013
32.96300985.7535.420496.33/7/2013
30.36301470.0637.530484.33/14/2013
31.83301967.4436.760497.43/21/2013
36.23302517.3435.700549.93/24/2013
34.20303026.2235.000508.93/29/2013
34.54303598.8839.000572.74/3/2013
31.18304129.2840.010530.44/17/2013
31.63304667.1640.000537.94/25/2013
35.02305210.936.520543.84/29/2013
35.99305807.6339.000596.75/5/2013
33.0230634138.000533.45/12/2013
34.35306874.136.510533.15/21/2013
31.75307346.835.020472.75/26/2013
31.20307797.834.000451.05/31/2013
34.30308322.7236.000524.96/5/2013
32.42308860.439.010537.76/10/2013
34.83309482.342.000621.96/15/2013
33.9531000236.010519.76/20/2013
37.34310377.623.660375.66/23/2013
32.33310886.237.010508.66/28/2013
33.22311408.737.000522.57/3/2013
33.89311956.2838.010547.67/9/2013
31.46312417.734.500461.47/13/2013
34.07312895.833.010478.17/16/2013
34.18313477.240.010581.47/18/2013
32.23313956.835.010479.67/21/2013
28.24314345.632.380388.87/26/2013
29.50314690.8827.530345.37/31/2013
29.76315178.6338.550487.88/6/2013
32.87315716.738.510538.18/11/2013
31.06316185.535.510468.88/17/2013
30.77316625.133.610439.68/23/2013
30.82317087.935.320462.88/29/2013
33.25317626.838.130538.99/9/2013
31.84318151.238.740524.49/15/2013
30.7131863637.130484.89/19/2013
31.75319082.6333.090446.69/23/2013
33.04319616.638.020534.09/28/2013
30.89320114.837.940498.210/2/2013
31.92320588.834.930474.010/8/2013
32.38321086.536.160497.710/12/2013
32.23321552.6334.020466.110/14/2013
29.07322031.838.770479.210/19/2013
31.61322476.333.080444.510/23/2013
30.31322952.136.920475.810/27/2013
33.81323469.3435.990517.311/1/2013
32.37323966.0636.100496.711/6/2013
29.49324417.3436.000451.311/10/2013
32.50324938.7537.740521.411/15/2013
31.55325424.3436.210485.611/21/2013
30.69325899.2536.400474.912/4/2013
28.73326373.9438.870474.712/8/2013
31.26326828.334.190454.412/14/2013
32.75327273.8432.000445.512/28/2013
30.78327745.3436.030471.51/3/2014
31.45328244.3437.320499.01/8/2014
31.57328739.9436.930495.61/15/2014
31.00329235.1637.580495.21/21/2014
30.21329646.1632.000411.01/26/2014
31.55330119.335.280473.22/2/2014
30.57330600.1637.000480.82/16/2014
34.59331143.0336.920542.92/28/2014
31.62331679.0639.880536.03/6/2014
34.50332215.4736.570536.43/15/2014
33.43332671.132.060455.63/20/2014
32.16333134.2233.870463.13/28/2014
32.98333645.636.470511.44/2/2014
33.21334356.9750.380711.44/9/2014
32.95334757.4428.590400.54/24/2014
33.81335219.5632.150462.14/27/2014
33.27335736.2836.530516.75/3/2014
37.12336239.2531.870503.05/13/2014
33.74336679.3430.680440.15/17/2014
35.03337226.2536.720546.95/25/2014
33.60337781.5638.880555.35/31/2014
34.79338206.0628.700424.56/7/2014
35.46338741.6635.530535.66/10/2014
34.37339263.835.740522.26/16/2014
35.48339763.3433.120499.56/22/2014
33.21340162.8828.300399.56/27/2014
34.47340648.2533.120485.47/3/2014
33.95341111.6632.110463.47/8/2014
36.65341663.3435.410551.77/16/2014
34.07342150.3433.620487.07/23/2014
35.81342698.5636.010548.27/27/2014
38.58343271.134.910572.58/1/2014
37.04343775.9432.060504.88/7/2014
33.98344297.0636.080521.18/13/2014
37.16344849.1334.950552.18/19/2014
36.50345362.8833.110513.88/26/2014
37.38345824.6629.060461.89/3/2014
35.77346365.7835.580541.19/4/2014
36.49346929.7536.360564.09/11/2014
37.56347475.1634.160545.49/16/2014
32.41347983.7236.910508.69/22/2014
35.89348466.3431.630482.69/27/2014
36.67348971.7532.420505.410/2/2014
33.51349493.9436.660522.210/8/2014
36.48349983.3431.560489.410/19/2014
33.17350462.433.970479.110/27/2014
31.40350934.6635.380472.310/31/2014
35.86351448.0633.680513.411/8/2014
33.77351991.6637.870543.611/28/2014
35.14352420.9428.740429.312/2/2014
31.38352936.4738.650515.512/11/2014
33.71353461.3436.630524.912/13/2014
32.28353962.436.510501.112/19/2014
36.59354536.0636.880573.712/24/2014
31.44355034.1637.270498.112/30/2014
33.39355537.435.450503.31/7/2015
33.44356067.4437.280530.01/14/2015
34.66356605.3436.510537.91/20/2015
31.40357110.2537.820504.91/27/2015
32.46357617.6636.770507.42/4/2015
31.94358143.4438.720525.82/13/2015
33.44358682.1337.890538.72/17/2015
33.42359160.5633.670478.42/17/2015
30.99359703.5641.220543.03/3/2015
32.30360202.3436.320498.83/16/2015
32.97360696.7535.270494.43/26/2015
35.95361234.0335.160537.34/7/2015
37.37362002.9448.400768.94/16/2015
33.25362538.1637.860535.24/23/2015
32.52363073.0338.690534.95/2/2015
34.21363620.3837.640547.35/9/2015
35.19364199.238.690578.85/15/2015
34.19364755.438.270556.25/21/2015
34.66365313.137.850557.75/27/2015
34.91365837.335.320524.26/6/2015
36.06366352.933.630515.66/12/2015
33.06366788.330.980435.46/17/2015
37.0936728031.180491.76/28/2015
31.44367780.437.440500.47/4/2015
36.62368342.636.110562.27/12/2015
37.20368944.2838.050601.77/18/2015
35.19369443.433.360499.17/21/2015
36.53370002.936.030559.57/29/2015
34.98370518.934.700516.08/6/2015
37.2237108936.030570.18/13/2015
34.42371638.237.530549.28/21/2015
32.68372197.0340.220558.88/31/2015
33.07372648.132.080451.19/12/2015
36.24373115.430.330467.39/17/2015
34.00373650.837.040535.49/23/2015
34.50376031.1162.3102380.310/22/2015
33.85376590.438.870559.310/29/2015
32.63377118.7838.090528.411/8/2015
32.67377665.139.330546.311/17/2015
32.66379549.2135.7101884.112/8/2015
32.71380004.732.760455.512/15/2015
31.52380447.733.060443.012/22/2015
34.22380960.2835.240512.612/31/2015
28.11381404.737.190444.41/9/2016
31.5538191337.900508.31/18/2016
34.09382434.635.993521.61/26/2016
29.52382887.2836.066452.72/3/2016
31.86383411.1338.675523.82/10/2016
31.12383862.7834.140451.72/16/2016
30.95384376.7239.058513.92/23/2016
34.06384847.132.484470.43/2/2016
34.82385363.534.886516.43/6/2016
30.29385788.8833.032425.43/12/2016
31.93386278.336.055489.43/19/2016
35.63386793.834.036515.53/24/2016
36.7838732634.036532.23/29/2016
34.2738780032.534474.04/2/2016
35.79388302.533.027502.54/7/2016
31.59388833.539.536531.04/13/2016
40.45389418.934.039585.44/17/2016
30.16389923.2239.326504.34/22/2016
41.87390491.831.943568.64/27/2016
36.26390991.532.414499.75/3/2016
35.54391495.633.365504.15/7/2016
36.56392050.235.686554.65/13/2016
37.02392609.635.549559.45/20/2016
33.31393093.234.149483.65/24/2016
33.27393601.635.946508.46/8/2016
35.48394106.933.496505.36/14/2016
35.94394663.136.399556.26/19/2016
36.09395199.2834.945536.26/24/2016
37.48395750.2834.578551.06/29/2016
37.40396227.730.028477.47/5/2016
36.38396678.229.126450.57/9/2016
35.98397193.233.667515.07/15/2016
35.35397685.3832.753492.27/20/2016
35.22398202.9734.570517.67/25/2016
34.78398712.1634.440509.28/1/2016
30.32399025.7524.331313.68/4/2016
0.002008840.0100.04/28/2016
33.18201462.340.997578.34/28/2016
33.82202013.838.359551.55/26/2016
31.41202548.540.040534.76/10/2016
32.57203067.737.498519.27/6/2016
As you can seem, every winter (November - March/April) my fuel economy went down.
You will also notice, once in a blue moon my MPG spiked to near 40 MPG. I believe those were rare times I lucked out and got pure gas with no ethanol in it.
My average because of those high spikes was 33 MPG after 3 years of monitoring.
Old Dec 27, 2016 | 08:27 AM
Marc87_RO's Avatar
I`m sorry, I must have converted to UK MPG not US MPG.
I will try again:
city: 20 US MPG
combined MPG: 23
hwy MPG: 25
Old Dec 27, 2016 | 08:34 AM
Marc87_RO's Avatar
No issues starting the engine, no poor performance, but I guess I will clean them anyway.
@mk378
Yes, I did the timping test in limp mode.
@TomCat39
I will try a compresion test and have the injectors cleaned.
Here in Europe we have 95 to 101 Octane fuel, I`m using 95, is good quality.
I will study your table, thank you!
Old Dec 27, 2016 | 08:37 AM
mk378's Avatar
When you decelerate (defined as TPS at 0% and engine rpm above idle speed), the EFI system is programmed to cut all fuel to the engine. The backfiring suggests that an injector is not closing all the way. You may see a difference in one of the spark plugs being black in the cylinder that is getting too much fuel.
Old Dec 27, 2016 | 08:45 AM
Marc87_RO's Avatar
It backfires like crazy, like 3 times in a second maybe more. Also the exhaust is kind of black. Might I have 1 or more injectors uncalibrated?
My motorcycle backfires as well, but is carbureted, so it is normal. 4 stroke Honda VFR 750.
@TomCat39
With a full tank I can travel 500 Km, (310. miles) maybe 550 Km (340 miles)
Old Dec 27, 2016 | 11:02 AM
Stonage07's Avatar
Mate we have the same issue, i'd love to hear more people on this subject.. Specifically 1.5 d series. I've got a d15z6 {vtec-e even} And it gets about 500 km on a full tank aswell. Pretty poor in my eyes, my car does backfire like yours aswell, you hear it better during idling... I wonder if that could be related to poor MPG, my performance and everything seems good. Motor sounds/looks healthy aside etc
Did you notice a difference in KMs on a full tank before and after the tune-up? Spark plugs, filters, etc
GL!
Old Dec 27, 2016 | 12:05 PM
Marc87_RO's Avatar
Same story as yours, backfires at idle and deceleration, car works just great, poor mpg though.
Seems logical to be an injector problem, like not closing when it has to...I will start here.
And no, all the tunning i have done did not help.
Old Dec 27, 2016 | 04:43 PM
eghatch9295's Avatar
Stancetard Hate Monger
i dont see wires/cap/rotor on your list.
Old Dec 27, 2016 | 05:19 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Just to provide a little clarity.
Europe rating is RON based from my research. Which is low speed testing for anti-detonation.
There is also a MON rating (not sure where it's used) and it's the high speed anti-detonation number.
USA ratings is based on AKI which is RON+MON/2 so is an average of the the high and low speed for it's ratings.
So really, I think a direct comparison is very challenging at best.
The above table I posted has been using USA AKI of 87 as the motor sees no benefit on the higher grade gases. It's designed for the economy gas of USA.
I think the closest equivalent over in Europe would be your 93 RON, the lowest that appears to be offered over there.
Also in my research it appears much of Europe is doing E05 gas which is 05% Ethanol while only a handful of European countries are using E10 which is typically sold here in North America but is just marketed as gasoline that "may" have up to 10% Ethanol. This was the story as up to 2014, might be more E10 being used in today's times and your country.
Also, I run a quality fuel injection cleaner through my car about once a year religiously. This might be part of the difference as everyone else is pointing out.
So, your MPG seems to be fairly impacted in comparison to my 3 years of results.
I found the RON/MON/AKI information on this site:
RON vs. Octane (US vs. Europe) Differences explained? - Rennlist Discussion Forums
Originally Posted by STLPCA
Chris - you are correct. Using 91 AKI gas should result in a slightly retarded ignition w/a resulting loss of power on a stock NA 993.
As you know, the "octane number" is a measure of a fuel's anti-knock (or pre-ignition) characteristics.
There are different accepted standards used to measure the anti-knocking characteristics of gas. The octane number you see at US pumps is the average of two such octane numbers; the Research Octane Number (RON) and the Motor Octane Number (MON). This average number is sometimes referred to as the Anti Knock Index ("AKI") or the US Cost of Living Council method ("CLC"). The RON and MON numbers are determined by American Society for Testing and Materials ("ASTM") laboratory tests. Thus, US octane numbers are described as, e.g., 93 AKI or 93 CLC. The equivalent RON number in other countries would be 98.
The RON method determines low speed and low load knock characteristics while the MON method tests high speed, high load, high temperature conditions such as exist during periods of high speed power accelerations, hill climbing, or any period of high power output. The MON method results in a higher octane number & is the more relevant value for racing.
Maybe more than you asked, but ... .
Old Dec 27, 2016 | 11:45 PM
Marc87_RO's Avatar
I will add them to the list, thank you.
@TomCat39
Lowest grade we can buy here is 95, so i have to stick to this. Some friends of mine who are driving civics can travel 650+ km out of a full tank, so I don`t think is the gas
Should I use a 16 degree BTDC with this fuel? or go more retarded?
Old Dec 28, 2016 | 07:39 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
That was my point. Your fuel likely has less ethanol which means you should get higher MPG not lower.
I am assuming your D15B7 is built the same as the USDM or CDM version with the same compression ratio, pistons, deck height etc.
If it is the same exact motor (ECU has the same designation of P06) then it should be 16 degrees.
I think you should follow everyone's advise of cleaning your injectors.
I know Wynn's makes a quality fuel injection cleaner called Power Charge. I don't know what products you have available to you in your country. Not all products are equal.
Old Dec 28, 2016 | 08:28 AM
Marc87_RO's Avatar
Yes, my civic is CMD, ecu P06, ignition set at 16 degrees, engine works just fine, I`m happy how it runs.
I will take the injectors down and clean them and check for defects.
I will update the thread once I finish this step.
Thank you everyone for helping! :D
Old Dec 28, 2016 | 08:48 AM
testify's Avatar
On vacation
What method do you use to calculate gas mileage?
It sounds like you are intelligent and would calculate it correctly, but I've seen a lot of people on car forums complain about poor gas mileage just to find out that they weren't actually calculating it correctly.
20mpg would likely be a huge loss in power as well, and youd likely notice something major is wrong with the motor.
Old Dec 28, 2016 | 12:01 PM
Marc87_RO's Avatar
Filled the tank to the maximum, traveled 100 Km and then filled the tank again.
I did this test many times and in different conditions.
Also, I run out of gas from a full tank to zero, in about 450-500 Km, 550 sometimes, depending where I`m driving.
Power wise everything is fine.
Old Dec 28, 2016 | 12:05 PM
testify's Avatar
On vacation
How many liters do you put in at 100km?
Old Dec 29, 2016 | 12:54 AM
Marc87_RO's Avatar
11.5 Liters (combined) that would be 3.037979 US gallons.
city only is up to 15 liters/100 Km, maybe more.
Old Dec 29, 2016 | 06:18 AM
DumpdEJ6's Avatar
I like the tuna here
I'd like to echo TomCat here regarding the compression test. All the new parts in the world won't help MPG if the rings are worn.
Old Dec 29, 2016 | 06:25 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
I'd clean your injectors with additive, and also make sure there are no exhaust leaks near your primary O2 sensor. There should not be any holes or leaks a couple of feet before and after the sensor. Compression test will help also. GL!
Old Mar 10, 2017 | 11:17 AM
Marc87_RO's Avatar
Hello, I`m back
The problem is still there.
What I did:
Removed the injectors and cleaned them, changed the o-rings, injectors are fine, no leaks.
I tested the compression, cold engine: 150 Psi; 152 Psi; 151 Psi; 150 Psi;
Failed a smoke test, this is the result:
Not sure why the test machine was reading the engine temperature 14 and 15 degrees, the engine was at operating temperature and running 5 minutes before test.
According to Autodata this is what I should get:
No headers leaks as far as I can tell.
To be honest, I do not know what I should test now...
Thank you!
Old Mar 10, 2017 | 11:27 AM
mk378's Avatar
Ohm test the ECT sensor. If the ECU really thinks the engine is 14 C, it will be in open loop mode which means it runs it rich, resulting in high emissions and poor mpg. It is only supposed to do that until warmed up, then switch to closed loop where it uses the O2 sensor to lean it out. Along those lines also make sure your thermostat is OK (not stuck open) and of the stock temperature rating.
Fuel pressure should also be checked. If the vacuum hose on the regulator is not hooked up, the pressure will be too high and it will run rich.
