How screwed is my engine?
Old Dec 25, 2016 | 09:15 AM
Vtec04's Avatar
Default How screwed is my engine?
Long story short, my wife drove my 2000 Dodge Stratus 2.4 into a curb and busted the radiator. She drove it about 7 miles at 30-40 MPH until it lost power, started pinging, lost oil pressure and died. The next day, it cranks but has no compression and does not start. Did it blow the head gasket? What else could have been damaged? Should I put a $400 tested junkyard engine in or try to fix this one? I want to keep this car going. Thank you for your advice.
Old Dec 25, 2016 | 09:31 AM
testify's Avatar
On vacation
Default Re: How screwed is my engine?
$400 for a used motor is significantly cheaper than rebuilding a severely damaged motor.
Old Dec 31, 2016 | 02:52 AM
exgr's Avatar
Homosexual by choice
THIS. used motor FTW.
Old Dec 31, 2016 | 02:40 PM
fcm's Avatar
fcm
Old Fart
Ditto both the above. 94
Old Jan 1, 2017 | 08:40 AM
B20VtecVillain's Avatar
what do you mean by "no compression". Was an actual compression test done and what were the resulting PSI readings on each cyl? A junkyard motor would likely be the easiest fix, but it very well could not be totally destroyed either. The 420A and similar 2.4 Mopar engines are actually decent engines and pretty strong. Typically just driving it for a few minutes over heated will not catastrophically kill it. Also, how hard was the curb hit. Are you sure the radiator is the only thing that was damaged?
Old Jan 3, 2017 | 08:57 PM
solomon93's Avatar
lost oil pressure? lose that motor for another used one
Old Jan 4, 2017 | 09:12 AM
motoxxxman's Avatar
is the dodgestratus a rare honda only available in certain markets? I've never heard of that model honda
Old Jan 4, 2017 | 04:27 PM
solomon93's Avatar
Lmao
Old Jan 7, 2017 | 02:20 PM
Vtec04's Avatar
The curb was hit just hard enough that it damaged the radiator but nothing else. What is likely the reason that it lost compression? Someone said that the pistons and or rings are likely damaged or melted. Could that be true? Could the head gasket just be blown? Thank you for taking the time to read my post and answer my questions.
sirguy01
Jul 6, 2006 09:03 PM
OnePointFive
May 4, 2006 12:29 PM
mugenhatchie
Apr 3, 2006 12:31 AM
KB Tuning
Nov 24, 2004 07:31 AM
vxnine
Oct 5, 2004 12:12 PM
