Honda Civic 1998 engine oil pressure light
My 1998 honda civic having D16y4 engine .. problem is engine oil pressure light turns when ever car is cold start and its goes off when temperature gets to normal like after 10 minutes.. what's should be the reasons . Should I use engine flush .. is there any blockage in the engine?
problem is your oil pump. stop driving the car immediately. pull the pan off, if youre lucky the pickup is just clogged.
Thank you dear... but if the problem is with oil plumb . Then light should be ON when the temperature of car is at normal operating temperature.. its light o's only On early morning in cold start . Rest of day its function normal..
