How accurate do you guys get on valve adjustments?
Old Nov 8, 2002 | 10:55 PM
Nameless RB26's Avatar
Default How acurate do you guys get on valve adjustments?
..for the B18c.
Do you do the .007 or .008 on the exhaust valves?
And do you do .006 or .007 on the intake valves?
I'm basically asking, which one do you lean more towards? The smaller gap or larger gap?
And which measurement is "better" in 100% acuracy? The smaller gap?
(yah.. stupid question, but please answer it..)
Old Nov 9, 2002 | 12:39 AM
Shark Tank's Avatar
Default Re: How acurate do you guys get on valve adjustments? (Nameless)
use smaller gap. the valves will naturally work themselves loose over time
Old Nov 9, 2002 | 07:09 AM
GRM Scott's Avatar
25 Year Member
i go tight as well, only once has one of my valves been tigther than spec when i went to adjust it, they tend to loosen.
Old Nov 9, 2002 | 08:36 AM
JPP's Avatar
JPP
I also use the tighter adjustment. Basically you make sure the 0.006 feeler gauge slides in the gap but not the 0.007 feeler gauge.
Using feeler gauge cannot garanty a precise adjustment of the gap. All you know is that the gap is between the feeler gauge sliding in and the one not sliding in. If you make the adjustment so that the higher feeler gauge (0.007 or 0.008)slides in then the gap is actually out of spec range(larger then 0.007 or 0.008).
[Modified by JPP, 12:38 PM 11/9/2002]
Old Nov 9, 2002 | 09:01 AM
rs's Avatar
rs
I'm accurate in the beginnnig, but as my back begins to freeze up I just want to finish the freaking job. Valve adjustments are a pain in the azz! There should be some sort of device that you could just hook up and it would loosen the locknut, adjust the valve, and most importantly tighten the locknut with out the valve screw moving. The little Honda tool sucks.
Old Nov 9, 2002 | 09:03 AM
b19coupe's Avatar
Default Re: How acurate do you guys get on valve adjustments? (rs)
Snap-on YA8895
Old Nov 9, 2002 | 12:59 PM
Default Re: How acurate do you guys get on valve adjustments? (b19coupe)
Snap-on YA8895
I broke two 10mm craftsman wrenches heating them up and bending them last night. I didn't have a real torch.. just propane lol.
I need that snap on tool
[Modified by Nameless, 1:59 PM 11/9/2002]
Old Nov 9, 2002 | 01:49 PM
Shark Tank's Avatar
here are some other tools
http://www.harborfreight.com/cpi/cta...emnumber=45113
Old Nov 9, 2002 | 01:53 PM
GSRrR's Avatar
Default Re: How acurate do you guys get on valve adjustments? (CART fan)
Hey that is really cheap. Anyone using these right now? Any comments?
Old Nov 9, 2002 | 02:01 PM
Default Re: How acurate do you guys get on valve adjustments? (GSRrR)
Sweet!
Old Nov 9, 2002 | 02:16 PM
R0476's Avatar
Default Re: How acurate do you guys get on valve adjustments? (Everybody)
Back to the top.
Anybody use these Harbor Freight adjustment tools?
Old Nov 9, 2002 | 02:22 PM
sackdz's Avatar
Default Re: How acurate do you guys get on valve adjustments? (R0476)
the snap on tool makes it easy.
Old Nov 9, 2002 | 02:28 PM
R0476's Avatar
Default Re: How acurate do you guys get on valve adjustments? (sackdz)
Thanks, like the link in sig.
Old Nov 9, 2002 | 02:38 PM
Mike95lude's Avatar
Definately go on the tighter spec on the valve adjustments. I was gonna do mine today, but I probably will tomorrow.
Old Nov 9, 2002 | 09:38 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Word to the back problems!!!!!!!!!
Old Nov 9, 2002 | 09:39 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Re: How acurate do you guys get on valve adjustments? (MUTANT X)
how about honda making hydrolic lifters so we never have to adjust the shitzzzzzzzzzz
Old Nov 9, 2002 | 11:13 PM
Tommy_Gunns's Avatar
Hydraulic lifters would wear out too fast at 9000 rpm revvings and that chit would cost an arm an a leg to replace.
I perfectly happy with solid lifters that are easy to adjust (ala Honda B series motors).
[Modified by Tommy_Gunns, 2:14 AM 11/10/2002]
Old Nov 9, 2002 | 11:19 PM
SurferX's Avatar
I use the Harbor Freight tool, it is that red/black tool on the right of the picture. Two thumbs up, makes things easy and quick. You can just turn the screwdriver with one hand while sliding the feeler with the other since it holds the nut in place for you. I believe it's the same type of tool as the Snap-on.
edit: yes I know I have oil on my timing belt. I happened to brush my hand over it by accident and I did clean it off afterward.
[Modified by SurferX, 12:26 AM 11/10/2002]
Old Nov 10, 2002 | 07:00 AM
Zeus's Avatar
Default Re: How acurate do you guys get on valve adjustments? (SurferX)
...I've used both, and you can't beat the Harbor Frieght valve tools for the buck ... only now I have three valve tools out of the set of four that I don't use...
[Modified by Zeus, 10:04 AM 11/10/2002]
Old Nov 10, 2002 | 10:45 AM
99_IntegR's Avatar
Default How often do you guys perform valve adjustments?
Sorry to get OT, but how often are you guys adjusting your valves? I had to get mind adjusted afer 17,000miles. Is that normal? As well, is it covered under warranty?
Old Nov 10, 2002 | 10:47 AM
Default Re: How often do you guys perform valve adjustments? (99_IntegR)
I adjust mine every spring along with changing out the spark plugs.
Old Nov 10, 2002 | 12:32 PM
Default Re: How often do you guys perform valve adjustments? (Tommy_Gunns)
I don't think it can hurt to adjust valves anytime in an engines life... as long as you do it right.
I believe Honda recomends a valve adjustment for dohc vtec engines at 30k.
I did this one at 13k miles..
Old Nov 10, 2002 | 12:33 PM
io_burn's Avatar
New User
Default Re: How often do you guys perform valve adjustments? (Nameless)
What are some symptoms to look for if your valves need adjusting?
Old Nov 10, 2002 | 12:40 PM
Default Re: How often do you guys perform valve adjustments? (io_burn)
If the valve lash is really loose, you will hear valve "chatter". Keep in mind ITR engines are a little noisier than most motors to begin with.
Old Nov 10, 2002 | 03:17 PM
Fuuma0083's Avatar
Yup and the sounds fades away when the engine get warmer.
