FL Turbo B-series E.G. Hatch
For SALE. NO TRADES. NO PART OUT
E.G. Hatch
Motor:
GSR Head
Civic Type R Cams
Gen. 1 Skunk2 Manifold
CSS Type R Block
8.8 Wiseco Pistons
GSR Crank
Eagle rods
Mahle clevite bearings
ARP rod bolts
ARP main studs
ARP Head studs
OEM Head Gasket
Trans:
GSR non lsd
XTD Stage 4 Race Clutch
10 lbs flywheel
Turbo kit:
Twisted Motions 50 trim
EMUSA Log Manifold
2.5in intercooler piping
eBay Intercooler
.065 oil restrictor
Mac 3 port solenoid
38mm wastegate with 22 psi spring (brand new)
Misc.
1000cc RC injectors (only seen pump gas)
450 walboro fuel pump (hard wired to the battery)
S300 with bbg (done by John Vega)
Boost gauge, wideband and oil pressure gauge
Aluminum radiator
Can include brand new front, rear camber kit and step colder NGK spark plugs
Needs an ignition switch, a distributor, and spark plug wires.
4500 obo
Text 347 55three 2488
E.G. Hatch
Motor:
GSR Head
Civic Type R Cams
CSS Type R Block
8.8 Wiseco Pistons
GSR Crank
Eagle rods
ARP rod bolts
ARP main studs
ARP Head studs
OEM Head Gasket
Trans:
GSR non lsd
10 lbs flywheel
Turbo kit:
EMUSA Log Manifold
eBay Intercooler
.065 oil restrictor
Mac 3 port solenoid
Misc.
Aluminum radiator
4500 obo
EG6 ON STANDS!
Jul 28, 2007 08:58 PM
[Caster]
59
Jul 27, 2003 06:46 AM
