2000 Honda CR-V Headlight Wiring Diagram
I am trying to tap into the high beam circuit at the stock connector for the projector shield solenoid ( working on the Bixenon Retrofit ) but the stock connector has three pronged.... anyone has the diagram to tell which Wire is for the high beam and which one is for the low beam ?
Thanks in advance !!!
Source the ground wire , usually Black lined . Then the other 2 is low beam power and high beam . As long as you get the ground correct , the other 2 can just be switched .
preston1802
Honda CR-V & Element
May 22, 2013 09:18 PM
