odd brake issue
have a 91 DX hatch, i was driving and all of a sudden the brakes started dragging, pedal hard as f@#$, had to pull off the side of the highway front brakes smoking like hell, let it sit for a while, got in driving fine then i start to feel them dragging again about 5 minutes into the trip. Nothing has been done or changed this just happened out of nowhere. wtf is going on
I think the floating pin might have jammed
Front disc brakes have a bolt that goes to a sliding pin so the caliper can move with pad wear and such, sThey're supposed to be greased, but sometimes they're not, and they seize.
i had this problem on a eg hatch i bought one time
it was just a shell with no engine but had this problem
the problem was a bad booster check valve
when they go bad
your brake pedal gets stiff and your front brake engage and stay engaged
to see if your is good is easy you remove the valve and blow in it with your mouth
try it on both sides and air should only pass from one side only
and it should pass threw easy
if you have to blow hard to get the valve to pass air threw then its bad
heres a pic of where its located
sometimes there inside the hose so you cant see them but to test is the same thing
just undo the hose and then blow into it
when they go bad
ginahoy
Suspension & Brakes
Oct 18, 2014 11:41 PM
faster_thn_hell
Jun 13, 2007 11:57 AM
