Wigglet93's B16A3 Novice turbo build.
Old Dec 6, 2016 | 10:33 AM
wigglet93's Avatar
Default Wigglet93's B16A3 Novice turbo build.
Hey honda-tech, i'm new to the Honda game, and I want to turbo my b16a3 93 civic. I was just wondering if you guys could give me some pointers as to what's a good manifold, injectors, turbo, like should i go t3 or t4, downpipe, wastegates, just anything to help. I've done a fair bit of research just want a final say before i carry out my plan.
Old Dec 6, 2016 | 12:29 PM
averyvm's Avatar
Default re: Wigglet93's B16A3 Novice turbo build.
There are so many variables to consider when choosing a turbo.
For a b16 I would personally pick the T3/T4 turbo with a .48 ar housing and 50 trim compressor wheel.
Old Dec 7, 2016 | 08:50 AM
TheShodan's Avatar
Moderator
Default Re: Wigglet93's B16A3 Novice turbo build.
Hi. Welcome to H-T's Technical Forums. Let's start you off with those FAQs at the top of the FI section with a grey background. those will give you all the guidance you need. This forum isn't your place to get extremely friendly when it comes to "General" information. Retrofiting Hondas has been done for over 20-23 years now. The methodology is rather simple.
https://honda-tech.com/forums/forced...2A%2A-1024174/
Once you get some specific questions as you go through your build progress, we'll be able to help you more. Make sure that since this is a thread, keep it relevant. We don't mind progress photos, but have a point; Purpose, goals, build lists, etc. Some aesthetics is ok, but if it's a lot of paint/body, we can move it over to another forum where you can do that portion of the build.
Good luck to you.. and good luck to the build.
Old Dec 7, 2016 | 08:19 PM
2kdrift's Avatar
T3, get good quality parts. go get yourself a go autoworks kit since this is your first turbo build that should take care of most your parts your asking about, I would stick to ID or FIC injectors sizing depends on your power goal
civic2slo
Apr 2, 2014 07:31 PM
JdM_Eg_6
Sep 13, 2004 04:27 PM
Civicdrgrcr
Jun 17, 2002 11:09 PM
M.A.R.C.
Jun 10, 2002 03:23 PM
hb_crazee
Oct 2, 2001 07:48 PM
