Timing Belt Tension VIDEO
Old Dec 6, 2016 | 05:45 AM
andyz's Avatar
Default Timing Belt Tension VIDEO
Too loose?
https://goo.gl/photos/pV8EuQz3SHTkoGN87
2000 accord LX stock 110,000 miles
Old Dec 6, 2016 | 07:51 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Timing Belt Tension VIDEO
Belt is not supposed to be high tension tight, just enough to remove the slack.
With crank and cam sprockets aligned, rotate crank 3 teeth to remove slack from between crank and cam.
Loosen acorn nut to allow spring tension to remove residual slack on the waterpump side, springs will not cause tension on the belt, merely removes the slack. With the lower cover off you can see this more readily, but not necessary.
Tighten acorn nut back.
Rotate crank over twice(720°) and place on TDC.
Verify cam sprocket has rotated once(360°), with the 'up' arrow in the up or down position, as long as the back side alignment marks are correct on the head you are golden.
If the car has 100Kmiles on it and the belt has not been replaced, or no records are found. It is overdue.
giovannie23
Aug 9, 2013 08:30 PM
wk9k
Mar 13, 2012 05:45 PM
7andaswitchblade
Jun 1, 2007 01:46 PM
teddy_dc2
Jul 6, 2006 09:15 AM
Shaun
Jun 14, 2006 06:29 AM
