Integra JDM front end hood latch problems
Whatsupp ok 1996 dc4. JDM itr front end conversion. I got a da hood latch and da hood release cable. Ran it all together and it won't pop. I'm glad I tested it with the side of a screwdriver lol. The cable had a bend in the plastic part that slides into the metal. Barely at all but it does have use. Cable is all there though. Do I need the da release part in the cabin under the dash? What y'all guys think?
I can't remember since I did mine over 10 years ago. I used my original hood latch release. Did you turn around the hood latch on the radiator support (see picture below)?
no I just have the cable running behind the center bar it's mounted to. What's holding that curve? How do I mount it like that?
I just have a DA hood latch mounted and the cable running behind it around into the latch. what do i have wrong?
I took the whole rack and pinon out so it can be restore (clean and re-paint) with everything else in the engine bay.
You will need a DC2/DC4 latch.
