Exhaust Manifold missing place for O2 sensor D16Y8
Old Nov 28, 2016 | 11:42 PM
Acirimis's Avatar
Default Exhaust Manifold missing place for O2 sensor D16Y8
I have a 1999 Honda Civic EX EJ8 D16Y8
In the service manual, the instructions on changing the O2 sensors on the D16Y8 motor show 1 O2 sensor in the Exhaust Manifold and 1 after the Cat. On my exhaust manifold, however, there is no O2 sensor nor a hole for the O2 sensor to bolt into. After a bit of investigating I find that my exhaust manifold is exactly the same as this one found at this ebay link
I have 2 CEL codes, P0136 (o2 Bank1 Sensor 2) and P0158 (o2 Bank 2 Sensor 2)
I understand that Sensor 2 means after the cat, so since the codes aren't screaming about Sensor 1 (pre cat) should I not worry about my exhaust manifold not having an o2 sensor? OR does it not having an o2 sensor cause more problems for me.
Old Nov 29, 2016 | 04:45 PM
civic402lx's Avatar
Default Re: Exhaust Manifold missing place for O2 sensor D16Y8
If its exactly like the eBay one you linked, then u are missing the B pipe which hold the 1st O2 sensor. Then your cat converter bolt onto that b pipe, then the 2nd O2 sensor is behind the cat converter. Followed by the rest of your exhaust system.
Get it?
Header, b pipe with O2 sensor, cat converter with 2nd O2 sensor, mid pipe and resonator, then muffler.
​​​​​​Look at this. @ EX/Si photo.. Not DX/CX..
http://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/96-00-civic-exhaust-help-74841/
See which part you are missing. Replace it..
Old Nov 29, 2016 | 06:20 PM
Acirimis's Avatar
Get it?
96-00 Civic Exhaust Help - HondaCivicForum.com
Wow damn, thank you so much for your help, I was thinking that someone did a shady job on the exhaust.
Old Nov 29, 2016 | 06:57 PM
mk378's Avatar
Honda calls the pipe that goes from the manifold, under the oil pan, to the inlet of the converter "pipe A" -- the long pipe under the center of the car starting at the converter and going back to near the right rear wheel is "pipe B". Pipe A also commonly called the "front pipe".
Old Nov 30, 2016 | 05:33 AM
civic402lx's Avatar
I stand corrected.
thank you for the correct info..
p.b.k
Jun 10, 2010 06:42 PM
raj_very
May 1, 2008 10:55 AM
team 15
Feb 19, 2007 04:49 PM
silentblackhat
Feb 15, 2005 10:33 AM
yorace2win
Oct 20, 2002 11:35 AM
