Recently replaced my climate control - now hazard button turns on dash?
Hey guys - long time no see. Been busy busy with life, kids and work.
Any how I still have my 1993 Honda Civic Si with now 316,000 miles. Couple months ago my fan switch stopped working, so I found a new/used climate control. Tore apart everything to get that bugger out. While I had it out I replaced the bulbs and found out my switch overheated and melted which is why the fan stopped working.
I did some surgery on the old and new climate controls. Took the good stuff out of the old one and removed the broken slider on the new one.
So I got everything cleaned, regreased and put everything back together on my dash (even replaced some of the bulbs on the speedo/odometer - but cracked a couple of the twist sockets).
I got the dash and consoles back together and when I went to plug the hazard button in my dash lights turned on. Thought it was a bit weird, so I pressed the hazard button and everything turned off.
Took a quick nap and went to start my car and everything looked fine until I turned the key to off. The car stayed running. Pulled the key out and the car still stayed running. Pressed the hazard button and everything turned off.
So I thought I would ask you guys what's going on before I pull my hair out tomorrow trying to track down what's going on.
Any ideas?
Thanks!
Mike
Any ideas?
Thanks!
Mike
I didn't think it was possible but yup had the hazard button plug upside-down.
So now I know for next time if I want to push start my car flip the hazard button
Now the sad thing is obviously everything plastic or rubber on my 93 Civic is getting brittle. I might have crushed the sockets for the bulbs on my speedo/odometer. 1-2 lights are out. Ugh.
Suck my DX
Mar 19, 2005 11:01 AM
