Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
No power after replacing altinator 2013 Civic
Old Nov 27, 2016 | 06:50 AM
arborguy's Avatar
Default No power after replacing altinator 2013 Civic
Coming back Thanksgiving stopped at rest area car would not start, got a jump!
Got charging system checked and altinator charging weak! Replaced altinator and now have 0" power
Old Nov 27, 2016 | 07:03 AM
arborguy's Avatar
Default Re: No power after replacing altinator 2013 Civic
I disconected negative from battery prior to removing alternator! Then reconected after installing! Car has no power and battery has plenty of juice!
Old Nov 28, 2016 | 06:22 AM
foumer's Avatar
W95 gives me a hard-on
check your grounds and the main fuse.
Old Nov 28, 2016 | 02:59 PM
arborguy's Avatar
Thank you!!
I will try that in the AM!!
Old Nov 29, 2016 | 04:13 AM
arborguy's Avatar
Not real clear on which fuse it is!! I know it's the 100 amp but the diagram on back of fuse box is not very clear. Could it be a multi fuse with screws or a square box like fuse?
Old Nov 29, 2016 | 07:38 AM
foumer's Avatar
It probably looks like this
Old Nov 29, 2016 | 08:35 AM
arborguy's Avatar
Thank you!
Old Dec 1, 2016 | 12:27 AM
arborguy's Avatar
Full power restored after replacing 100 amp main fuse!
Thanks!!
Old Dec 2, 2016 | 04:16 AM
foumer's Avatar
Old Dec 27, 2016 | 03:34 AM
William Lim's Avatar
Hi I am new member here , I am facing loose power as well after my battery flat is it also related to fuse as well?
my car is civic fd2 2006
thanks
Old Dec 27, 2016 | 05:08 PM
97emsedan's Avatar
thanks
Have your alternator checked for output. Most likely the alternator is weakening and you are losing the ability to charge your battery and power your auxiliary systems.
Have you installed extra stereo equipment? Most people will upgrade power draws without improving the power supply at the same time.
Old Dec 28, 2016 | 05:29 AM
i didn't install any extra stereo , I send to workshop check been inform it is good condition for alternator
I bought is second hand car all is in ori condition just unable to think what cause it lost power after change the battery
BrandonPell
Aug 30, 2018 11:03 AM
utahcoheed
Aug 8, 2005 07:10 PM
ekoms31
15
Jun 21, 2005 10:42 AM
4doorH22
Audio / Security / Video
Sep 6, 2002 07:34 PM
